CPU watercooling
5 Nov 2014
Hello all,
I have been looking at the corsair CPU all in one water systems range but I am a bit unsure of which one to go for.
my current CPU is a I7 950 currently running on stock settings and using the following CPU cooler
http://www.overclockers.co.uk/showproduct.php?prodid=HS-080-AK
I was looking at the H75 and H90, I did have a look at the watercooling kits (V6 etc) but its a bit too much and in my current case I don't have the room for the pump etc.
Any all in one water coolers will do your current set up, a Dual rad would give you some over clocking head room, the one thing to note is an all in one is no better then high end air cooling and costs more.
your current CPU cooler will be better then any single rad all in one's that are on the market.
if you want to upgrade your option would be THIS
But THIS is a lot better and a lot cheaper, i would go AIR or custom cooler
thanks for the reply, would I get better cooling\lower temps if I did a custom water cooler setup rather than a all in one?
I don't know too much about water cooling but seen a few builds with it and looks good!
I did look at the dual rad one but at the moment I don't have a case that can take it, will be changing it soon though
