Not sure where this should go but here seems to be logical
I recently upgraded my old i3 [email protected] to an i5 [email protected] and when stress testing at full load the system makes a high pitched whining noise, this never happened with the i3 and only seems to manifest in the i5 above 4ghz. As soon as I stop the prime95 test it stops whining.
If I apply slight sideways pressure to the heatsink it changes the pitch of the whine as it moves on the cpu. Obviously this isn't something I regularly do, I discovered it when I put my hand against the cpu fan to see if it was vibrating.
Motherboard is a GA H55M UD2H, heatsink is a thermalright truespirit 140bw applied with old arctic silver ceramique (found a tube of it in the loft from years ago!). Temperatures are good at aroun 65-70°C full load small ffts in prime95.
What's causing this? Is this something I should worry about? Can I stop it?
