CPU with Virtualization
hi, im finding that my CPU is always the component that seems to be lacking on my system. It is a custom built system, all the parts are actually bought from OCUK. Im happy with my system, it suits my needs and was very cheap, however i think an upgrade is needed. I have put OSX on it and I want to use Virtualization (parallels), however the current CPU does not allow that.
Here are the specs:
Cpu: Pentium(R) Dual-Core CPU E5200 @ 2.50GHz, Socket 775 LGA
Mobo:EP43-DS3L
Chipset:
Northbridgem - Intel P45/P43/G45/G43 rev. A2
Southbridge - Intel 82801JR (ICH10R) rev. 00
GPU: NVIDIA GeForce 9800 GT
OS: Windows 7
I would appreciate some advice please on what is a good CPU to upgrade to that will be compatible with my system.
I found this list:
http://www.gigabyte.com/support-downloads/cpu-support-popup.aspx?pid=2847
Thanks.
If you have any other suggestions, please feel free to voice them.
Here are the specs:
Mobo:EP43-DS3L
Chipset:
OS: Windows 7
I found this list:
Thanks.
