CPU-Z Help?
18 Nov 2011
Kent
Hello all,
When I open the graphics tab on CPU-Z its shows this...
It shows up fine in GPU-Z, strange! :confused:
Any ideas?
Thanks
Strange. May just be a bug and a conflict between cpu-z and the version of amd drivers you are using. Wouldn't say it is anything to be concerned about if everyhing shows up normal on gpu-z and the card is performing normally.
