CPU-Z info
25 Feb 2007
I have just loaded CPU-Z on new system, i have a intel e6600 running at stock 2.4 or so i thought, when i have looked at the info in CPU-Z it says
core speed 1.632
multiplier x6
bus speed 272
rated FSB 1088
Is this right or should it show core speed of 2.4
Noobe at this sort of think any help muchly appreciated. Thanks
You need to disable SpeedStep in your BIOS if you want it to run at full speed all the time.
Your not quite at stock either, Bus Speed 272.. It should be 266. your motherboards being a little cheeky :), Your chip will be running at 2450mhz or so.
