- 19 Nov 2006
- Barton Upon Humber/Whitby/Scarborough
Earlstreetblue said:I'm assuming this is something that can be turned on or off from within the bios then?
Nope, maybe you just never noticed it before? or perhaps you reset some things in BIOS before installing Vista?Earlstreetblue said:Hmm,wasn't doing this when I was running XP, recently moved to Vista, would that have anything to do with it I wonder.
Nicely written, that pretty much sums up the only argument for switching EIST off, however I have run an E6300 for 6 months (@3150MHz) with EIST enabled and I have had no cause for concern or any stability issues (you know I'm a stickler for stability!), the chip just chills out at 2700MHz when its not under load.Corasik said:Unless I am much mistaken, all Intel Core 2's with speedstep, regardless of their full speed multi, drop to a multi of 6, and cut the VCore. So assuming this is correct speedstep has the potential for issues with the lower muliplier processors.
Big.Wayne said:Nicely written, that pretty much sums up the only argument for switching EIST off, however I have run an E6300 for 6 months (@3150MHz) with EIST enabled and I have had no cause for concern or any stability issues (you know I'm a stickler for stability!), the chip just chills out at 2700MHz when its not under load.
If I was having an issue while trying to work out a max overclock I would consider turning EIST off for the purposes of trouble-shooting though.
I'm not sure why I am a fan of this tech, I guess when I was doing my research for CD2 (late starter Dec 2006) I did noticed everyone saying 'Disable this' and 'Disable that' and I wondered what the basis for this advice was? However I'm the kinda person who if you tell me not to do something without a reason that I can understand I will go right ahead and try it out anyway!![]()
Just standard stuff really, 450MHz-FSB x 7 multi, 1.350vCore, 1.450vNB, 1.8vDimm.funksteruk2 said:what settings have you got?
