CPU-Z not reporting same voltage as CPU Voltage
26 Jan 2005
Dorset
Hi,
In my P6T SE's BIOS I have set my "CPU Voltage" to 1.225V
CPU-Z indicates that it is 1.216V
When I view the BIOS' "Hardware Monitor" page it also indicates 1.216V
Thinking it might be something to do with Speedstep I disabled it. Still the same.
Does anybody know why this difference exists?
Many thanks
Thank you.
I had read about VDrop and I am surprosed at its effect even while navigating around the BIOS. That has to the lowest possible loading for the CPU other than the machine being turned off! :D
