CPU-Z Q6600 @ 3.28
Caporegime
8 Nov 2008
Hi, downloaded this and the core voltage reads over 1.5 :eek:
Is that a little too high for comfort? Thought it was supposed to be around 1.32 - 1.45 tops.
It also reads as stepping = B and revision = G0. That's the more overclockable model right?
Do you have vcore on manual or auto,as some boards over compensate when in auto mode.
The G0 is the lower power model which is the one to get.
I'm actually running my q6600 at 3.4Ghz on 1.34 volts with an ip35 - you should definitely be fine with around 1.3 especially seeing as you have a good cooler to keep the temps down ontop of that.
