Hi
CPU-Z reporting the core speed at 2997.7 MHz and the bus speed at 333.4 MHz, rated fsb at 1332.6, the multiplier x9.0 and I have disabled in the bios EIST Mode and the CIE Function. I have changed the CPU clock instead of 333MHz bus speed to 334MHz. The Dram Speed has gone to 1069. I get a report now on the CPU-Z my core speed at 3000.6 MHz and the multiplier has stayed the same and the bus speed is showing 333.4MHz and rated FSB is showing 1333.6MHz.
Temp reporting
Core0 34
Core1 41
My question is as I increase from the bus speed 333MHz to 334MHz, is this going to damage the board or CPU?
Any advice would be appreciated.
Motherboard Lanparty UT x48-T3RS
Bios:03/26/2009
CPU: E8400 C0
Memory:OCZ3P13331G
Timings:7 7 7 16
PSU:650W
GPU:8800GTS (640MB)
Seagate 500 GB SATA II at 7200rpm
Operating systems:WIn VISTA 32sp1
Temp reporting
Core0 34
Core1 41
Bios:03/26/2009
CPU: E8400 C0
Memory:OCZ3P13331G
Timings:7 7 7 16
PSU:650W
GPU:8800GTS (640MB)
