cpu-z reports much higher vcore than bios?
2 Dec 2007
Leeds
Hi,
i have just overclocked my 3570k to 4.5ghz! the problem im having is my vcore is set to 1.32 in gigabyte bios but in cpu-z its showing as 1.46? any idea why this is happening?
Hi, are you using the latest CPU-Z, never came across this before but up till now, been using CPU-Z for years never known it be wrong. Try another bit of software to check > openhardwaremonitor that's what l use to monitor my Vcore under load, temps, etc for a quick check running in the back ground all the time.
http://openhardwaremonitor.org/
My CPU-Z reads completely the wrong value on my 2500k.
It says my VCore is 1.044V, instead of around 1.35V. I use HWMonitor instead, plus it comes with a ton of temperature stats.
