11 Jun 2011 at 18:24 #1 Sime Sime Soldato Joined 8 Nov 2006 Posts 2,866 Hey all, ive just started overclocking my PC. Can someone explain if the following image is correct. I should have 4x1gb OCZ DD2 PC2-6400 im just curious as CPU-Z says that its only 400mhz. Does all look well?
11 Jun 2011 at 18:26 #2 Surveyor Surveyor Caporegime Joined 5 Sep 2010 Posts 25,573 I can't see the image but the effective speed of your memory is doubled as it's DDR (Double Data Rate). So if it says 400MHz that's doubled to 800MHz which is correct for PC2-6400.
11 Jun 2011 at 18:26 #3 RJC RJC Don Joined 29 May 2005 Posts 29,082 Location Kent You will need double what CPU-z shows.
11 Jun 2011 at 18:28 #4 Surveyor Surveyor Caporegime Joined 5 Sep 2010 Posts 25,573 Tried to re-post your image but couldn't.
11 Jun 2011 at 18:32 #5 Surveyor Surveyor Caporegime Joined 5 Sep 2010 Posts 25,573 Delete. Duplicate post. Last edited: 11 Jun 2011
11 Jun 2011 at 18:33 #6 BEn_2600+ BEn_2600+ Associate Joined 9 Jul 2004 Posts 663 Location Rotherham Heres the image as above isnt working.
11 Jun 2011 at 18:35 #7 RJC RJC Don Joined 29 May 2005 Posts 29,082 Location Kent There you go Uploaded with ImageShack.us
11 Jun 2011 at 18:59 #8 dimention dimention Associate Joined 1 Jun 2011 Posts 68 uyea thats ddr2 so its double lol
