cpu z voltage changing
Caporegime
1 Jun 2006
Notts
well i just got my fenrir installed and at 3.6 on my p2 955. all seems fine and passes all benchies ive run today.
i just fired up latest cpuz and i was a little intrigued to why the volts were fluctuating :confused: is this cause its a new version is this normal ?
it is not going crazy but it i never use this so i dont know if ok :p
You probably mean a vdrop?
Under load your volts will drop a bit due to stress putted on mobo and also some motherboards will under/overvolt a bit as well.
Also it might be the cool&quiet that drops your CPU voltage/speed when on idle.
