just put CPU-Z on my machine to check out the CPU and i noticed that it is giving different information about my memory to what i had supposedly purchased.
how accurate is it when it comes to identifying you components?
if you are talking about the timings, you may need to manually input the correct timings in the bios, if its the frequency, you may be underclocking the ram currently
The memory tab is what it's actually running at, you'll need to manually adjust the timings in the BIOS, making sure you set the right voltage as well.
