CPUID HWMonitor - Results Help?
23 Dec 2010
Hey Guys!
I've just ran CPUID HWMonitor and am wondering if these results are good?
I haven't got a clue on Voltages and all of that...
It's obviously not reading the +12V correctly otherwise I doubt the PC would be working.
If it really is around 8V then something is seriously wrong.
Never heard of an NTK 500W Gamer PSU.
How much did that cost?
And how have you ended up with 6GB of RAM on a Core 2 system?
Its a competitors brands name so I've abbreviated it, its actually fairly good.
6GB RAM? Isn't that normall? I got a 4gb stick and a 2gb stick in my system.
How do I change the Voltages on this?
I'll take your word for it.
Normal is having 2 identical sticks.
You can't. It's either working correctly or it isn't.
If you PC runs properly then I'd say it's a mistake with the program.
It runs fairly sweetly to be honest, can you suggest another program with capabilities of viewing these results?
After just looking at it has confirmed that its alright.
I also just noticed that my motherboard has onboard overclock settings on it for the Q8300. Can anyone tell me what I should have it on (It goes up in 5%s).
Air Cooled btw.
