Hi there,need a little advice please,i been using cpuz to monitor my pc but when i looked at the memory speed which should be running at 1600mhz it says that it is running at 800mhz in the DRAM frequency box....is this normal as 2x800=1600...is this correct?
thanks in advance
thanks in advance
