CPUz SPD wrong info?
10 May 2007
Telford
CPUz SPD stating wrong info?
CPUz states that my max memory bandwidth is PC2-6400 (400MHz) tho I have 2gb Corsair Dominator Twin2X2048-8500C5D (1066MHz). Is this right?
Based on your screen shots, your only running your ram at pc2-6400 speeds, well just below actually... Perhaps thats why it says it your max, try running your ram closer to it designed speed and see what it shows in cpu-z.
If I run my ram closer to its speed, that will change the ratio. Will that matter much?
EDIT: Have tried that. Have taken ram freq to 1016mhz just short of stock and it's still showin up as pc2-6400
Most 8500 RAM is exactly the same chips as the 6400 stuff just speed binned depending on their capabilities - the higher quality stuff becomes 8500 parts... for several reasons including compatibility the SPD is programmed with 6400.
Search on these forums and you'll see its been asked several times recently.
