21 Jun 2008 at 00:35 #1 johnyccc johnyccc Associate Joined 24 Sep 2006 Posts 1,267 I am hearing some short crackles in my music once for every two or so presses of keys. Does anyone have any idea as to the cause? Thanks!
21 Jun 2008 at 00:52 #2 helmutcheese helmutcheese Permabanned Joined 19 Jun 2007 Posts 10,717 Location InURmama USB ?
21 Jun 2008 at 15:04 #4 helmutcheese helmutcheese Permabanned Joined 19 Jun 2007 Posts 10,717 Location InURmama johnyccc said: What about it? Click to expand... IS the KB connected by USB or PS2 ?
21 Jun 2008 at 16:43 #6 helmutcheese helmutcheese Permabanned Joined 19 Jun 2007 Posts 10,717 Location InURmama I would have thought the issue was USB, but do you have a LATENCY setting in your Mobos Bios for the PCI slots, so you can adjust the Soundcard.
21 Jun 2008 at 17:03 #7 johnyccc johnyccc Associate OP Joined 24 Sep 2006 Posts 1,267 I have "PCI Latency Timer" : 32, 64*, 96 .. 248
21 Jun 2008 at 17:05 #8 helmutcheese helmutcheese Permabanned Joined 19 Jun 2007 Posts 10,717 Location InURmama Ok you will need try them, normally 32 and 64 is suffice. This also used to solve peeps X-FI issues.
21 Jun 2008 at 21:30 #9 johnyccc johnyccc Associate OP Joined 24 Sep 2006 Posts 1,267 Well it was on 64 and so i popped it up to 128. Ill see if it helps. thanks for your assistance
