Caporegime
- 13 May 2003
- Warwickshire
Hi all
I'm about to redecorate our hall stairs and landing. It'll be a big job with lots of prep work to get a decent finish, one of which is to sort quite a few hairline cracks in the 1960s plaster that's since been skimmed few times.
Having watched a few YouTube videos, my plan is to Dremel / pad saw the cracks to widen them, fill them with expanding foam, cut away the excess foam with a scraper, then use two coats of Gyproc Easifill 45 with scrim tape to hopefully make a decent finish with no returning cracks, at least for a while.
Did this approach sound ok? Had anyone had success with other methods or products? Unfortunately taking it all back to brick isn't something we want to entertain.
Thanks.
Thanks.
