Ive got a bit of a puzzler going on with the Golf (1.8t)
Some morning (particularly when cold) when you start and drive away it will have a pronounced stutter when you might light throttle inputs, it feels like the car has plain stalled for a second.
The other day i could feel it doing it in the evening (rare, normally only when cold)
No fault codes, ive monitored ignition timing, afr, throttle position, everything, no obvious signs
For it to cut so abruptly im thinking crank sensor, but the tacho doesnt show any signs
If voltage dropped at the fuel pump, do you think it could cause such an abrupt stutter?
There are similar posts on mk4 boards but no one ever seems to cure it
