Crappy Pipex DNS? Help! :(
24 Apr 2007
Southport
Hi, I run my own webserver from home, based on Windows XP with Apache running.
Everything works fine, I host a small school's website and it's nippy enough. I have the domain moongold.net, and all works as it should with no problems, browsing is fine.
The only issues I have are:
- Images won't load if I embed them into a page, for example if I made an ebay listing and put the image source as http://moongold.net/images/whatever.jpg it won't work, but if I replace the moongold.net part with my actual IP it's fine.
- The site doesn't cache in Google - search for Moongold and you'll see what I mean. It just says something about frames? I don't want to run the site in frames, but don't know how to change this.
- The moongold.net always stays in the address bar, nomatter where you navigate.
If I find anything else, I'll post it. Does anyone know how to help these, or if not, the best domain registrar that could help me have all these things working normally?
Thanks! :)
moongold.net resolves to 194.154.164.82 - is that the correct IP address? If not, you need to ask your domain host to change it to the correct one.
Nope, thats the address of the server that is putting my website in frames, I found that a few days ago - very annoying!
I just want it to point straight at my site without frames or any other rubbish :)
