Hi all.
Pc has been running fine for months but I've not been gaming much or if I have it's been wreckfest
I recently reinstalled rdr2 as I've not tried it on the 3080ti but was disappointed with my PC completely crashing once the game has run for a few minutes.
I just get a black screen with no light on the GPU, pressing reset restarts the PC, power button does nothing....
Spec is
3080ti FE no overclock
5950x no overclock
MSI tomahawk max (latest bios)
32gb 8pack B die (4x8gb)
Seasonic Focus Plus 750W 80 Plus Gold
All air cooled in a pc011xl
Running win 10 with latest drivers.
First thing I tried was dropping the memory speed to 2666, when that didn't help I removed half the ram and then swapped the sticks. Crashed exactly the same regardless of memory settings.
I can run cinebench and 3d mark without issue.
I can also play wreckfest with no crashes.
Temperatures are ok given the high ambient and everything is clean.
I did get the rdr2 benchmark to complete with the game on lowest graphics settings and resolution 1024x768 60hz
Once I changed back to 1440p 165hz the crash was back.
So what do you reckon the problem is?
GPU
PSU
Motherboard?
Any other tests or ways to narrow it down to one component?
I don't have any spare parts.
Thanks for any help.
Spec is
5950x no overclock
GPU
PSU
Motherboard?
