- 5 Sep 2017
Hi All
Looking for a little advice as i am having issues with my PC (bought Apr 2018)
Custom Intel i7-8700K @ 4.9GHz System
- Seasonic Focus Plus 650W 80 Plus Gold Modular Power Supply
- Intel Core i7-8700K 3.7GHz (Coffee Lake) Socket LGA1151 Processor - Retail
- Gigabyte GeForce GTX 1070Ti WindForce 8192MB GDDR5 PCI-Express
- Samsung 500GB 860 EVO SSD 2.5" SATA 6Gbps 64 Layer 3D V-NAND Solid
State Drive (MZ-76E500B/EU)
- WD 1TB Blue 7200rpm Internal Hard Drive
- Alphacool Eisbaer LT360 CPU AIO Water Cooling Unit - 240mm (11446)
- Asrock Z370 Extreme 4 Intel Z370 (Socket 1151) DDR4 ATX Motherboard
- Team Group Vulcan T-Force 16GB (2x8GB) DDR4 PC4-25600C16 3200MHz
I have what I believe is a solid spec (aided by this community!) so a little confused as to why I am now seeing the system fail on start (before Windows screen) or, if lucky, load but then crash afree a few minutes (if i run a game it performs terribly, audio is messed up and then eventually the system just turns off)
Could it be a PSU issue? (Google's fav suggestion but with no suggestion of how to confirm) if so, is that likely to be underpowered or a failing PSU ?
Hope you can help!
Cheers
Hope you can help!
Cheers
