Crash on Load *DRIVER_POWER_STATE_FAILURE BSOD*
27 Jul 2012
After half an hour of gameplay (i.e. RS6 Siege), or a few hours of desktop usage, my PC crashes with the BSOD as above.
My specs:
Ryzen 3600
B450 Tomahawk
2x16gb crucial AT 3200mhz cl16 ram
Corsair AX860 Power Supply
all at stock (ram is at 2400mhz).
I sent this back to OverclockersUK, my GPU, and they reported no faults. What can I do? I've ran DRAM Calculator MEMTEST (24GB) @ 150% scope with no failures.
I've changed the PCIE Gen auto to gen 3.
I've got a seperate PCIE Cable for my gpu so that power is delivered better(?)
What can I do to isolate the fault? Could my motherboard have a faulty PCIE 1 slot? Faulty DRAM?
