Hey all, im just a little lost with my overclocking, only just started and im struggling now. I replaced the cpu cooler with http://www.arctic-cooling.com/catalo...th=1_42&mID=69 and i replaced the gpu cooler with http://www.arctic-cooling.com/catalo...ath=2_&mID=103 .Then i thought id try to overclock, i upped the FSB from 333 -360, and lowered the dram freq. Just be doing this alone when i run real temp to check the temp of the cores, its going as high as 85 degrees under stress. And this is only at 360? my case cooling is fine , i have enough air supply in my case and its nice and cool. Im worried about pushing any further than 360 because the temp is reaching that level. I did find a video on youtube showing what someone did to overclock his E8400 3ghz dual chip, which is the same as mine, i did exactly what he said which was change the FSB to 400 and up the voltage to 1.23750, when my pc booted up i got a bluescreen crash, so went into bios and reset it back. Now im lost as to what to do, i know very little about changing the cpu voltages. Not sure what to do next, pretty much lost and worried about pushing it too far to get more crashes. Any advice / help would be appreciated.
Pc specs
E8400 Wolfdale @ 3ghz dual core
Asus P5Q motherboard
8 gig ddr2 1066mhz corsair dominator
8800 gtx640mb
800 watt coolermaster psu
Viewsonic 24inch widescreen full hd hdmi monitor 1920 x 1080
running vista 64 bit ultimate.
My temps are - WITH NO OVERCLOCK!
gpu 39
system 27
cpu 25
aux 26
hd0 20
hd1 31
core 0 39
core 1 45
I have a full size fan and if i leave that blowing towards my case with the side off the core 0 drops to 30 or 29, so this is what ill do to help with airflow after overclocking.
Pc specs
8800 gtx640mb
gpu 39
system 27
cpu 25
aux 26
hd0 20
hd1 31
core 0 39
core 1 45
