Crash! Unreal engine help
Permabanned
30 Dec 2021
Yorkshire
So i have been getting crash's over the last few weeks playing squads this is the error report, any idea guys?
LoginId:1b32bba147337f5dba624f8b03fe4f05
EpicAccountId:
Fatal error: [File:C:/buildWork/d9b2387fd600ba3c/UnrealEngine/Engine/Source/Runtime/D3D12RHI/Private/D3D12Util.cpp] [Line: 684] Streamline/DLSSG present failed at C:\buildWork\d9b2387fd600ba3c\Squad\Plugins\Streamline\Source\StreamlineD3D12RHI\Private\StreamlineD3D12RHI.cpp:288 with error DXGI_ERROR_DEVICE_REMOVED with Reason: DXGI_ERROR_DEVICE_HUNG
SquadGame
SquadGame
sl_dlss_g
sl_dlss_g
sl_dlss_g
sl_dlss_g
sl_interposer
sl_interposer
SquadGame
SquadGame
SquadGame
SquadGame
SquadGame
SquadGame
SquadGame
SquadGame
SquadGame
kernel32
ntdll
Try rolling back to 551.76 nVidia drivers if using newer, if it is with the 14700KF you might be unlucky and need to use the Intel Baseline power profile and/or manually dial in boost power limits, though I've not seen many reports of that issue with the 14700.
Looks like a GPU driver or hardware type of error message, so could be GPU related crashes, but we can see you have a 14th gen high end Intel CPU and these CPUs are known to currently have significant issues with crashing in Unreal Engine games - so my suggestion is to do a BIOS update for your motherboard and use the Intel baseline profile and check if the game still crashes
My bios is upto date and power limits already reduced. It keeps causing DLSS but in game I have DLSS disabled as my system can run the game good
I’ll look into the GPU drivers
