Crash WHEA-logger event 18 when GPU driver installed
25 Aug 2013
My nephew's PC I built for him has started crashing randomly, no BSOD, just hard reset.
Event viewer shows WHEA-logger event 18 at the time of the crashes.
Doesn't occur in safe mode and I narrowed it down to the GPU driver. When not installed the system iis fine, as soon as the adrenalin driver is installed is starts to crash.
Anyone seen this before or have a solution/suggestion?
I'm currently trying to mess around with the GPU settings via afterburner to see if adjusting the voltage will help.
Specs:
Ryzen 3100 (stock)
Asrock B450M Steel Legend
16Gb Klev Bolt X 300MHz (at 2666)
XFX R9 390 8Gb
Cooler Master MWE White 600W
Thanks in for any help!
