- 14 Nov 2023
- United Kingdom
Hi There
I don't know what I've done/what's happened - had a perfect system no issues with 6800XT. Got an 7900XT with work so decided to upgrade - put it in and updated the driver. Could not get it to work longer than 10 minutes in games (that would previously run with no problems) - without crashing to desktop. Tried deleting/re-installing drivers but nothing worked. Decided it must be a faulty card, so put my old 6800XT back in. Thought I was ok for a while, but then the crashes started on my 6800XT. I've just finished rolling back to the driver to the last version I had 23.10.2 - which was working perfectly, now it's not.
Anyone experienced this sort of thing and know a fix?
System specs are:
- 7800X3D
- Asrock B650 Riptide
- Gskill DDR5 - 32 GB (x2 16)
- Power supply - Corsair RX850
- Storage - Samsung EVO 850 1tb
- Windows 11 version 22H2
System specs are:
- 7800X3D
