Crashing and locking after purchase
16 Nov 2006
Hi guys just bought a SyncMaster 245B and 2GB of GEIL RAM. Installed both with ease. But no my photoshop locks up after sometime and when I play CS:Source is locks up or crashes. I have no clue. Is there something i need to activate or something? Any info you need I can supply, thanks!
try runnign memtest and seeing if one stick of ram is faulty. if not post you pc specs here including screenshots if you can from CPU-Z and most importantly the voltage for your ram or from your bios
Hi guys, thanks for the speedy reply.
My motherboard is the ASRock 775Dual-VSTA
I ran the Memtest and it does detect both rams. During 1 hour and 36 minutes it detected also 967 errors, whether that is normal I do not know.
I will add my DXDiag file to the next post.
System Information
Time of this report: 11/17/2007, 09:49:29
Machine name: MASTER
Operating System: Windows XP Home Edition (5.1, Build 2600) Service Pack 2 (2600.xpsp_sp2_gdr.070227-2254)
Language: English (Regional Setting: English)
System Manufacturer: 75D8U
System Model: 775Dual-VSTA
BIOS: Default System BIOS
Processor: Intel(R) Core(TM)2 CPU 6300 @ 1.86GHz (2 CPUs)
Memory: 2048MB RAM
Page File: 623MB used, 2809MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.2180 32bit Unicode
DxDiag Notes
DirectX Files Tab: No problems found.
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Music Tab: No problems found.
Input Tab: No problems found.
Network Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: NVIDIA GeForce 7900 GS
Manufacturer: NVIDIA
Chip type: GeForce 7900 GS
DAC type: Integrated RAMDAC
Device Key: Enum\PCI\VEN_10DE&DEV_0292&SUBSYS_82231043&REV_A1
Display Memory: 256.0 MB
Current Mode: 1920 x 1200 (32 bit) (60Hz)
Monitor: SyncMaster 245B/245BW(Digital)
Monitor Max Res: 1920,1200
Driver Name: nv4_disp.dll
Driver Version: 6.14.0011.6375 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 10/4/2007 17:14:00, 5783424 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: n/a
VDD: n/a
Mini VDD: nv4_mini.sys
Mini VDD Date: 10/4/2007 17:14:00, 6854464 bytes
Device Identifier: {D7B71E3E-41D2-11CF-146B-28A200C2CB35}
Vendor ID: 0x10DE
Device ID: 0x0292
SubSys ID: 0x82231043
Revision ID: 0x00A1
Revision ID: 0x00A1
Video Accel: ModeMPEG2_A ModeMPEG2_B ModeMPEG2_C ModeMPEG2_D ModeWMV9_B ModeWMV9_A
Deinterlace Caps: {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
DDraw Test Result: Not run
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not run
Sound Devices
Description: Realtek HD Audio output
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0888&SUBSYS_18491E01&REV_1000
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: RtkHDAud.sys
Driver Version: 5.10.0000.5247 (English)
WHQL Logo'd: Yes
Date and Size: 4/17/2006 08:31:26, 4262912 bytes
Other Files:
Driver Provider: Realtek Semiconductor Corp.
HW Accel Level: Full
Cap Flags: 0xF5F
Min/Max Sample Rate: 8000, 192000
Static/Strm HW Mix Bufs: 33, 31
Static/Strm HW 3D Bufs: 33, 31
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: Yes, Yes
I3DL2(tm) Listen/Src: Yes, Yes
Sensaura(tm) ZoomFX(tm): No
Registry: OK
Sound Test Result: Not run
Sound Capture Devices
Description: Realtek HD Audio input
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x41
Format Flags: 0xFFF
DirectMusic
DLS Path: C:\WINDOWS\SYSTEM32\drivers\GM.DLS
DLS Version: 1.00.0016.0002
Acceleration: n/a
Ports: Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal, Default Port
MPU-401, Hardware (Kernel Mode), Input, No DLS, External
MPU-401, Hardware (Kernel Mode), Output, No DLS, External
Microsoft MIDI Mapper [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
Microsoft GS Wavetable SW Synth [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
MPU-401 [Emulated], Hardware (Not Kernel Mode), Output, No DLS, External
MPU-401 [Emulated], Hardware (Not Kernel Mode), Input, No DLS, External
Registry: OK
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Device Name: PTZ-930
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x056A, 0x00B2
FF Driver: n/a
Device Name: Wacom Virtual Hid Driver
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x056A, 0x1001
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Poll w/ Interrupt: No
Registry: OK
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x1106, 0x3038
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 2/28/2006 12:00:00, 57600 bytes
| Driver: usbd.sys, 2/28/2006 12:00:00, 4736 bytes
Gameport Devices
+ VIA Standard PCI to ISA Bridge
| Matching Device ID: pci\ven_1106&dev_3337
| Service: isapnp
| Driver: isapnp.sys, 8/17/2001 12:58:02, 35840 bytes
+-+ Standard Game Port
| | Matching Device ID: *pnpb02f
| | Service: gameenum
| | Driver: gameenum.sys, 8/3/2004 23:08:22, 10624 bytes
PS/2 Devices
+ Standard 101/102-Key or Microsoft Natural PS/2 Keyboard
| Matching Device ID: *pnp0303
| Service: i8042prt
| Driver: i8042prt.sys, 2/28/2006 12:00:00, 52736 bytes
| Driver: kbdclass.sys, 2/28/2006 12:00:00, 24576 bytes
+ Terminal Server Keyboard Driver
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
| Driver: termdd.sys, 8/4/2004 00:01:08, 40840 bytes
+ HID-compliant mouse
| Vendor/Product ID: 0x046D, 0xC01E
| Matching Device ID: hid_device_system_mouse
| Service: mouhid
| Driver: mouclass.sys, 8/3/2004 21:58:34, 23040 bytes
| Driver: mouhid.sys, 8/17/2001 12:48:00, 12160 bytes
| Service: mouhid
+ Wacom Mouse
| Matching Device ID: hid\wacomvirtualhid&col03
| Upper Filters: wacommousefilter
| Service: mouhid
| Driver: wacommousefilter.sys, 2/14/2006 12:18:52, 5632 bytes
+ Terminal Server Mouse Driver
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
DirectPlay Service Providers
DirectPlay8 Modem Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 Serial Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 IPX Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 TCP/IP Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
Internet TCP/IP Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2180)
IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2180)
Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2180)
Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2180)
DirectPlay Voice Wizard Tests: Full Duplex: Not run, Half Duplex: Not run, Mic: Not run
DirectPlay Test Result: Not run
Registry: OK
DirectPlay Adapters
DirectPlay8 Serial Service Provider: COM1
DirectPlay8 TCP/IP Service Provider: Local Area Connection - IPv4 -
DirectPlay Voice Codecs
Voxware VR12 1.4kbit/s
Voxware SC06 6.4kbit/s
Voxware SC03 3.2kbit/s
MS-PCM 64 kbit/s
MS-ADPCM 32.8 kbit/s
Microsoft GSM 6.10 13 kbit/s
TrueSpeech(TM) 8.6 kbit/s
DirectPlay Lobbyable Apps
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 100.1 GB
Total Space: 152.6 GB
File System: NTFS
Model: Maxtor 6G160E0
Drive: D:
Model: PIONEER DVD-RW DVR-111D
Driver: c:\windows\system32\drivers\cdrom.sys, 5.01.2600.2180 (English), 2/28/2006 12:00:00, 49536 bytes
Drive: E:
Model: ZT3833S DNZ824X SCSI CdRom Device
System Devices
Name: VIA CPU to AGP Controller
Device ID: PCI\VEN_1106&DEV_B198&SUBSYS_00000000&REV_00\3&267A616A&0&08
Driver: n/a
Name: VIA PCI to PCI Bridge Controller
Device ID: PCI\VEN_1106&DEV_A208&SUBSYS_00000000&REV_00\3&267A616A&0&10
Driver: C:\WINDOWS\system32\DRIVERS\pci.sys, 5.01.2600.2180 (English), 8/3/2004 22:07:48, 68224 bytes
Name: VIA Standard Host Bridge
Device ID: PCI\VEN_1106&DEV_7308&SUBSYS_00000000&REV_00\3&267A616A&0&07
Driver: n/a
Name: VIA I/O APIC Interrupt Controller
Device ID: PCI\VEN_1106&DEV_5308&SUBSYS_53081849&REV_00\3&267A616A&0&05
Driver: n/a
Device ID: PCI\VEN_1106&DEV_4308&SUBSYS_00000000&REV_00\3&267A616A&0&04
Driver: n/a
Name: VIA Standard PCI to PCIE Bridge
Device ID: PCI\VEN_1106&DEV_337B&SUBSYS_00000000&REV_00\3&267A616A&0&98
Name: VIA Standard PCI to ISA Bridge
Device ID: PCI\VEN_1106&DEV_3337&SUBSYS_00000000&REV_00\3&267A616A&0&88
Driver: C:\WINDOWS\system32\DRIVERS\isapnp.sys, 5.01.2600.0000 (English), 8/17/2001 12:58:02, 35840 bytes
Name: Microsoft UAA Bus Driver for High Definition Audio
Device ID: PCI\VEN_1106&DEV_3288&SUBSYS_08881849&REV_10\4&23B2F3EA&0&0898
Driver: C:\WINDOWS\system32\DRIVERS\hdaudbus.sys, 5.10.0001.5013 (English), 1/7/2005 16:07:18, 138752 bytes
Device ID: PCI\VEN_1106&DEV_3208&SUBSYS_00000000&REV_00\3&267A616A&0&03
Driver: n/a
Name: VIA USB Enhanced Host Controller
Device ID: PCI\VEN_1106&DEV_3104&SUBSYS_31041849&REV_86\3&267A616A&0&84
Driver: C:\WINDOWS\system32\drivers\usbehci.sys, 5.01.2600.2180 (English), 2/28/2006 12:00:00, 26624 bytes
Driver: C:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.2180 (English), 2/28/2006 12:00:00, 142976 bytes
Driver: C:\WINDOWS\system32\usbui.dll, 5.01.2600.2180 (English), 8/4/2004 00:56:48, 74240 bytes
Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.2180 (English), 2/28/2006 12:00:00, 57600 bytes
Driver: C:\WINDOWS\system32\hccoin.dll, 5.01.2600.2180 (English), 2/28/2006 12:00:00, 7168 bytes
Name: VIA Rhine II Fast Ethernet Adapter
Device ID: PCI\VEN_1106&DEV_3065&SUBSYS_30651849&REV_7C\3&267A616A&0&90
Driver: C:\WINDOWS\system32\DRIVERS\fetnd5b.sys, 3.27.0000.0412 (English), 11/11/2003 10:41:08, 41984 bytes
Name: VIA Rev 5 or later USB Universal Host Controller
Device ID: PCI\VEN_1106&DEV_3038&SUBSYS_30381849&REV_A0\3&267A616A&0&83
Driver: C:\WINDOWS\system32\drivers\usbuhci.sys, 5.01.2600.2180 (English), 2/28/2006 12:00:00, 20480 bytes
Device ID: PCI\VEN_1106&DEV_3038&SUBSYS_30381849&REV_A0\3&267A616A&0&82
Device ID: PCI\VEN_1106&DEV_3038&SUBSYS_30381849&REV_A0\3&267A616A&0&81
Device ID: PCI\VEN_1106&DEV_3038&SUBSYS_30381849&REV_A0\3&267A616A&0&80
Name: VIA Ultra VLINK Controller
Device ID: PCI\VEN_1106&DEV_287E&SUBSYS_00000000&REV_00\3&267A616A&0&8F
Driver: n/a
Device ID: PCI\VEN_1106&DEV_2308&SUBSYS_00000000&REV_00\3&267A616A&0&02
Driver: n/a
Device ID: PCI\VEN_1106&DEV_1308&SUBSYS_00000000&REV_00\3&267A616A&0&01
Driver: n/a
Name: Standard Dual Channel PCI IDE Controller
Device ID: PCI\VEN_1106&DEV_0591&SUBSYS_05911849&REV_80\3&267A616A&0&78
Driver: C:\WINDOWS\system32\DRIVERS\pciidex.sys, 5.01.2600.2180 (English), 2/28/2006 12:00:00, 25088 bytes
Driver: C:\WINDOWS\system32\DRIVERS\atapi.sys, 5.01.2600.2180 (English), 2/28/2006 12:00:00, 95360 bytes
Driver: C:\WINDOWS\system32\DRIVERS\pciide.sys, 5.01.2600.0000 (English), 2/28/2006 12:00:00, 3328 bytes
Name: VIA Bus Master IDE Controller
Device ID: PCI\VEN_1106&DEV_0571&SUBSYS_05711849&REV_07\3&267A616A&0&79
Driver: C:\WINDOWS\system32\DRIVERS\viaide.sys, 1.00.0001.0001 (English), 2/28/2006 12:00:00, 5376 bytes
Device ID: PCI\VEN_1106&DEV_0308&SUBSYS_00000000&REV_00\3&267A616A&0&00
Driver: n/a
Name: NVIDIA GeForce 7900 GS
Device ID: PCI\VEN_10DE&DEV_0292&SUBSYS_82231043&REV_A1\4&D553C31&0&0010
Driver: C:\WINDOWS\system32\DRIVERS\nv4_mini.sys, 6.14.0011.6375 (English), 10/4/2007 17:14:00, 6854464 bytes
Driver: C:\WINDOWS\system32\nv4_disp.dll, 6.14.0011.6375 (English), 10/4/2007 17:14:00, 5783424 bytes
Driver: C:\WINDOWS\system32\nvsvc32.exe, 6.14.0011.6375 (English), 10/4/2007 17:14:00, 155716 bytes
Driver: C:\WINDOWS\system32\nvapi.dll, 6.14.0011.6375 (English), 10/4/2007 17:14:00, 364544 bytes
Driver: C:\WINDOWS\system32\nvoglnt.dll, 6.14.0011.6375 (English), 10/4/2007 17:14:00, 6750208 bytes
Driver: C:\WINDOWS\system32\nvcpl.dll, 6.14.0011.6375 (English), 10/4/2007 17:14:00, 8491008 bytes
Driver: C:\WINDOWS\system32\nvmctray.dll, 6.14.0011.6375 (English), 10/4/2007 17:14:00, 81920 bytes
Driver: C:\WINDOWS\system32\nvwddi.dll, 6.14.0011.6375 (English), 10/4/2007 17:14:00, 81920 bytes
Driver: C:\WINDOWS\system32\nvnt4cpl.dll, 6.14.0010.11122 (English), 10/4/2007 17:14:00, 286720 bytes
Driver: C:\WINDOWS\system32\nvmccs.dll, 6.14.0011.6375 (English), 10/4/2007 17:14:00, 229376 bytes
Driver: C:\WINDOWS\system32\nvdisps.dll, 6.14.0011.6375 (English), 10/4/2007 17:14:00, 6344704 bytes
Driver: C:\WINDOWS\system32\nvdispsr.dll, 6.14.0011.6375 (English), 10/4/2007 17:14:00, 5509120 bytes
Driver: C:\WINDOWS\system32\nvgames.dll, 6.14.0011.6375 (English), 10/4/2007 17:14:00, 3334144 bytes
Driver: C:\WINDOWS\system32\nvgamesr.dll, 6.14.0011.6375 (English), 10/4/2007 17:14:00, 3166208 bytes
Driver: C:\WINDOWS\system32\nvmccss.dll, 6.14.0011.6375 (English), 10/4/2007 17:14:00, 188416 bytes
Driver: C:\WINDOWS\system32\nvmccssr.dll, 6.14.0011.6375 (English), 10/4/2007 17:14:00, 458752 bytes
Driver: C:\WINDOWS\system32\nvmobls.dll, 6.14.0011.6375 (English), 10/4/2007 17:14:00, 1150976 bytes
Driver: C:\WINDOWS\system32\nvmoblsr.dll, 6.14.0011.6375 (English), 10/4/2007 17:14:00, 2854912 bytes
Driver: C:\WINDOWS\system32\nvvitvs.dll, 6.14.0011.6375 (English), 10/4/2007 17:14:00, 3551232 bytes
Driver: C:\WINDOWS\system32\nvvitvsr.dll, 6.14.0011.6375 (English), 10/4/2007 17:14:00, 3629056 bytes
Driver: C:\WINDOWS\system32\nvwss.dll, 6.14.0011.6375 (English), 10/4/2007 17:14:00, 2371584 bytes
Driver: C:\WINDOWS\system32\nvwssr.dll, 6.14.0011.6375 (English), 10/4/2007 17:14:00, 2441216 bytes
Driver: C:\WINDOWS\help\nvcpl.hlp, 10/4/2007 17:14:00, 177897 bytes
Driver: C:\WINDOWS\help\nvwcplen.hlp, 10/4/2007 17:14:00, 55444 bytes
Driver: C:\WINDOWS\system32\nvcod.dll, 1.00.0000.0035 (English), 10/4/2007 17:14:00, 36864 bytes
Driver: C:\WINDOWS\system32\nvcodins.dll, 1.00.0000.0035 (English), 10/4/2007 17:14:00, 36864 bytes
DirectX Components
ddraw.dll: 5.03.2600.2180 English Final Retail 2/28/2006 12:00:00 266240 bytes
ddrawex.dll: 5.03.2600.2180 English Final Retail 2/28/2006 12:00:00 27136 bytes
dxapi.sys: 5.01.2600.0000 English Final Retail 2/28/2006 12:00:00 10496 bytes
d3d8.dll: 5.03.2600.2180 English Final Retail 2/28/2006 12:00:00 1179648 bytes
d3d8thk.dll: 5.03.2600.2180 English Final Retail 2/28/2006 12:00:00 8192 bytes
d3d9.dll: 5.03.2600.2180 English Final Retail 2/28/2006 12:00:00 1689088 bytes
d3dim.dll: 5.01.2600.0000 English Final Retail 2/28/2006 12:00:00 436224 bytes
d3dim700.dll: 5.03.2600.2180 English Final Retail 2/28/2006 12:00:00 825344 bytes
d3dramp.dll: 5.01.2600.0000 English Final Retail 2/28/2006 12:00:00 590336 bytes
d3drm.dll: 5.01.2600.0000 English Final Retail 2/28/2006 12:00:00 350208 bytes
d3dxof.dll: 5.01.2600.0000 English Final Retail 2/28/2006 12:00:00 47616 bytes
d3dpmesh.dll: 5.01.2600.0000 English Final Retail 2/28/2006 12:00:00 34816 bytes
dplay.dll: 5.00.2134.0001 English Final Retail 2/28/2006 12:00:00 33040 bytes
dplayx.dll: 5.03.2600.2180 English Final Retail 2/28/2006 12:00:00 229888 bytes
dpmodemx.dll: 5.03.2600.2180 English Final Retail 2/28/2006 12:00:00 23552 bytes
dpwsock.dll: 5.00.2134.0001 English Final Retail 2/28/2006 12:00:00 42768 bytes
dpwsockx.dll: 5.03.2600.2180 English Final Retail 2/28/2006 12:00:00 57344 bytes
dplaysvr.exe: 5.03.2600.2180 English Final Retail 2/28/2006 12:00:00 30208 bytes
dpnsvr.exe: 5.03.2600.2180 English Final Retail 2/28/2006 12:00:00 18432 bytes
dpnet.dll: 5.03.2600.2180 English Final Retail 2/28/2006 12:00:00 375296 bytes
dpnlobby.dll: 5.03.2600.2180 English Final Retail 2/28/2006 12:00:00 3584 bytes
dpnaddr.dll: 5.03.2600.2180 English Final Retail 2/28/2006 12:00:00 3584 bytes
dpvoice.dll: 5.03.2600.2180 English Final Retail 2/28/2006 12:00:00 212480 bytes
dpvsetup.exe: 5.03.2600.2180 English Final Retail 2/28/2006 12:00:00 83456 bytes
dpvvox.dll: 5.03.2600.2180 English Final Retail 2/28/2006 12:00:00 116736 bytes
dpvacm.dll: 5.03.2600.2180 English Final Retail 2/28/2006 12:00:00 21504 bytes
dpnhpast.dll: 5.03.2600.2180 English Final Retail 2/28/2006 12:00:00 35328 bytes
dpnhupnp.dll: 5.03.2600.2180 English Final Retail 2/28/2006 12:00:00 60928 bytes
dpserial.dll: 5.00.2134.0001 English Final Retail 2/28/2006 12:00:00 53520 bytes
dinput.dll: 5.03.2600.2180 English Final Retail 2/28/2006 12:00:00 159232 bytes
dinput8.dll: 5.03.2600.2180 English Final Retail 2/28/2006 12:00:00 181760 bytes
dimap.dll: 5.01.2600.0000 English Final Retail 2/28/2006 12:00:00 44032 bytes
diactfrm.dll: 5.01.2600.0000 English Final Retail 2/28/2006 12:00:00 394240 bytes
joy.cpl: 5.03.2600.2180 English Final Retail 2/28/2006 12:00:00 68608 bytes
gcdef.dll: 5.01.2600.0000 English Final Retail 2/28/2006 12:00:00 76800 bytes
pid.dll: 5.03.2600.2180 English Final Retail 2/28/2006 12:00:00 35328 bytes
gameenum.sys: 5.01.2600.2180 English Final Retail 8/3/2004 23:08:22 10624 bytes
dsound.dll: 5.03.2600.2180 English Final Retail 2/28/2006 12:00:00 367616 bytes
dsound3d.dll: 5.03.2600.2180 English Final Retail 2/28/2006 12:00:00 1294336 bytes
dswave.dll: 5.03.2600.2180 English Final Retail 2/28/2006 12:00:00 19456 bytes
dsdmo.dll: 5.03.2600.2180 English Final Retail 2/28/2006 12:00:00 181760 bytes
dsdmoprp.dll: 5.03.2600.2180 English Final Retail 2/28/2006 12:00:00 71680 bytes
dmusic.dll: 5.03.2600.2180 English Final Retail 2/28/2006 12:00:00 104448 bytes
dmband.dll: 5.03.2600.2180 English Final Retail 2/28/2006 12:00:00 28672 bytes
dmcompos.dll: 5.03.2600.2180 English Final Retail 2/28/2006 12:00:00 61440 bytes
dmime.dll: 5.03.2600.2180 English Final Retail 2/28/2006 12:00:00 181248 bytes
dmloader.dll: 5.03.2600.2180 English Final Retail 2/28/2006 12:00:00 35840 bytes
dmstyle.dll: 5.03.2600.2180 English Final Retail 2/28/2006 12:00:00 105984 bytes
dmsynth.dll: 5.03.2600.2180 English Final Retail 2/28/2006 12:00:00 103424 bytes
dmscript.dll: 5.03.2600.2180 English Final Retail 2/28/2006 12:00:00 82432 bytes
system.dll: 1.01.4322.2407 English Final Retail 7/11/2007 09:31:37 1232896 bytes
Microsoft.DirectX.Direct3D.dll: 9.05.0132.0000 English Final Retail 6/15/2007 08:44:16 473600 bytes
Microsoft.DirectX.Direct3DX.dll: 5.04.0000.3900 English Final Retail 5/2/2007 13:58:12 2676224 bytes
Microsoft.DirectX.Direct3DX.dll: 9.04.0091.0000 English Final Retail 5/2/2007 13:58:13 2846720 bytes
Microsoft.DirectX.Direct3DX.dll: 9.05.0132.0000 English Final Retail 5/2/2007 13:58:15 563712 bytes
Microsoft.DirectX.Direct3DX.dll: 9.06.0168.0000 English Final Retail 6/15/2007 08:44:16 567296 bytes
Microsoft.DirectX.Direct3DX.dll: 9.07.0239.0000 English Final Retail 5/2/2007 13:58:16 576000 bytes
Microsoft.DirectX.Direct3DX.dll: 9.08.0299.0000 English Final Retail 6/13/2007 16:13:58 577024 bytes
Microsoft.DirectX.Direct3DX.dll: 9.09.0376.0000 English Final Retail 5/2/2007 13:58:17 577536 bytes
Microsoft.DirectX.Direct3DX.dll: 9.10.0455.0000 English Final Retail 5/2/2007 13:58:20 577536 bytes
Microsoft.DirectX.DirectDraw.dll: 5.04.0000.2904 English Final Retail 6/15/2007 08:44:16 145920 bytes
Microsoft.DirectX.DirectInput.dll: 5.04.0000.2904 English Final Retail 6/15/2007 08:44:17 159232 bytes
Microsoft.DirectX.DirectPlay.dll: 5.04.0000.2904 English Final Retail 6/15/2007 08:44:17 364544 bytes
Microsoft.DirectX.DirectSound.dll: 5.04.0000.2904 English Final Retail 6/15/2007 08:44:18 178176 bytes
Microsoft.DirectX.AudioVideoPlayback.dll: 5.04.0000.2904 English Final Retail 6/15/2007 08:44:15 53248 bytes
Microsoft.DirectX.Diagnostics.dll: 5.04.0000.2904 English Final Retail 6/15/2007 08:44:15 12800 bytes
Microsoft.DirectX.dll: 5.04.0000.2904 English Final Retail 6/15/2007 08:44:14 223232 bytes
dx7vb.dll: 5.03.2600.2180 English Final Retail 2/28/2006 12:00:00 619008 bytes
dx8vb.dll: 5.03.2600.2180 English Final Retail 2/28/2006 12:00:00 1227264 bytes
dxdiagn.dll: 5.03.2600.2180 English Final Retail 2/28/2006 12:00:00 2113536 bytes
mfc40.dll: 4.01.0000.6140 English Final Retail 2/28/2006 12:00:00 924432 bytes
mfc42.dll: 6.02.4131.0000 English Final Retail 2/28/2006 12:00:00 1028096 bytes
wsock32.dll: 5.01.2600.2180 English Final Retail 2/28/2006 12:00:00 22528 bytes
amstream.dll: 6.05.2600.2180 English Final Retail 2/28/2006 12:00:00 70656 bytes
devenum.dll: 6.05.2600.2180 English Final Retail 2/28/2006 12:00:00 59904 bytes
dxmasf.dll: 6.04.0009.1133 English Final Retail 8/22/2006 03:05:26 498742 bytes
mciqtz32.dll: 6.05.2600.2180 English Final Retail 2/28/2006 12:00:00 35328 bytes
mpg2splt.ax: 6.05.2600.2180 English Final Retail 2/28/2006 12:00:00 148992 bytes
msdmo.dll: 6.05.2600.2180 English Final Retail 2/28/2006 12:00:00 14336 bytes
encapi.dll: 5.03.2600.2180 English Final Retail 2/28/2006 12:00:00 20480 bytes
qasf.dll: 11.00.5721.5145 English Final Retail 10/18/2006 21:47:18 211456 bytes
qcap.dll: 6.05.2600.2180 English Final Retail 2/28/2006 12:00:00 192512 bytes
qdv.dll: 6.05.2600.2180 English Final Retail 2/28/2006 12:00:00 279040 bytes
qdvd.dll: 6.05.2600.2180 English Final Retail 2/28/2006 12:00:00 385024 bytes
qedit.dll: 6.05.2600.2180 English Final Retail 2/28/2006 12:00:00 562176 bytes
qedwipes.dll: 6.05.2600.2180 English Final Retail 2/28/2006 12:00:00 733696 bytes
quartz.dll: 6.05.2600.2749 English Final Retail 8/30/2005 03:54:26 1287168 bytes
strmdll.dll: 4.01.0000.3936 English Final Retail 8/21/2006 08:52:08 246814 bytes
iac25_32.ax: 2.00.0005.0053 English Final Retail 2/28/2006 12:00:00 199680 bytes
ir41_32.ax: 4.51.0016.0003 English Final Retail 2/28/2006 12:00:00 848384 bytes
ir41_qc.dll: 4.30.0062.0002 English Final Retail 2/28/2006 12:00:00 120320 bytes
ir41_qcx.dll: 4.30.0064.0001 English Final Retail 2/28/2006 12:00:00 338432 bytes
ir50_32.dll: 5.2562.0015.0055 English Final Retail 2/28/2006 12:00:00 755200 bytes
ir50_qc.dll: 5.00.0063.0048 English Final Retail 2/28/2006 12:00:00 200192 bytes
ir50_qcx.dll: 5.00.0064.0048 English Final Retail 2/28/2006 12:00:00 183808 bytes
ivfsrc.ax: 5.10.0002.0051 English Final Retail 2/28/2006 12:00:00 154624 bytes
mswebdvd.dll: 6.05.2600.2180 English Final Retail 2/28/2006 12:00:00 204288 bytes
ks.sys: 5.03.2600.2180 English Final Retail 8/3/2004 22:15:22 140928 bytes
ksproxy.ax: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:58 130048 bytes
ksuser.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:44 4096 bytes
stream.sys: 5.03.2600.2180 English Final Retail 8/3/2004 22:08:04 48640 bytes
mspclock.sys: 5.03.2600.2180 English Final Retail 8/3/2004 22:58:40 5376 bytes
mspqm.sys: 5.01.2600.2180 English Final Retail 8/3/2004 22:58:42 4992 bytes
mskssrv.sys: 5.03.2600.2180 English Final Retail 8/3/2004 22:58:42 7552 bytes
swenum.sys: 5.03.2600.2180 English Final Retail 2/28/2006 12:00:00 4352 bytes
mstee.sys: 5.03.2600.2180 English Final Retail 8/3/2004 21:58:40 5504 bytes
ipsink.ax: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:58 16384 bytes
mpeg2data.ax: 6.05.2600.2180 English Final Retail 2/28/2006 12:00:00 118272 bytes
ndisip.sys: 5.03.2600.2180 English Final Retail 8/3/2004 22:10:14 10880 bytes
streamip.sys: 5.03.2600.2180 English Final Retail 8/3/2004 22:10:14 15360 bytes
msvidctl.dll: 6.05.2600.2180 English Final Retail 2/28/2006 12:00:00 1428480 bytes
slip.sys: 5.03.2600.2180 English Final Retail 8/3/2004 22:10:18 11136 bytes
nabtsfec.sys: 5.03.2600.2180 English Final Retail 8/3/2004 22:10:30 85376 bytes
ccdecode.sys: 5.03.2600.2180 English Final Retail 8/3/2004 22:10:18 17024 bytes
vbisurf.ax: 5.03.2600.2180 English Final Retail 2/28/2006 12:00:00 30720 bytes
msyuv.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:46 17408 bytes
kstvtune.ax: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:58 61952 bytes
ksxbar.ax: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:58 43008 bytes
kswdmcap.ax: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:58 90624 bytes
vfwwdm32.dll: 5.01.2600.2180 English Final Retail 8/3/2004 23:56:48 53760 bytes
wstcodec.sys: 5.03.2600.2180 English Final Retail 8/3/2004 22:10:22 19328 bytes
wstdecod.dll: 5.03.2600.2180 English Final Retail 2/28/2006 12:00:00 50688 bytes
DirectShow Filters
WDM Streaming VBI Codecs:
NABTS/FEC VBI Codec,0x00200000,2,1,,5.03.2600.2180
CC Decoder,0x00200000,2,1,,5.03.2600.2180
WST Codec,0x00200000,1,1,,5.03.2600.2180
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,,
WMAPro over S/PDIF DMO,0x00600800,1,1,,
WMA Voice Decoder DMO,0x00600800,1,1,,
Mpeg4s Decoder DMO,0x00800001,1,1,,
WMV Screen decoder DMO,0x00800001,1,1,,
WMVideo Decoder DMO,0x00800001,1,1,,
Mpeg43 Decoder DMO,0x00800001,1,1,,
Mpeg4 Decoder DMO,0x00800001,1,1,,
WMT MuxDeMux Filter,0x00200000,0,0,wmm2filt.dll,2.01.4026.0000
Full Screen Renderer,0x00200000,1,0,quartz.dll,6.05.2600.2749
RealPlayer Video Filter,0x00200000,1,1,rdsf3260.dll,6.00.0012.1791
DV Muxer,0x00400000,0,0,qdv.dll,6.05.2600.2180
Color Space Converter,0x00400001,1,1,quartz.dll,6.05.2600.2749
WM ASF Reader,0x00400000,0,0,qasf.dll,11.00.5721.5145
Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,11.00.5721.5145
AVI Splitter,0x00600000,1,1,quartz.dll,6.05.2600.2749
WMT AudioAnalyzer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.05.2600.2749
Indeo® video 5.10 Compression Filter,0x00200000,1,1,ir50_32.dll,5.2562.0015.0055
Windows Media Audio Decoder,0x00800001,1,1,msadds32.ax,8.00.0000.4487
Sonic HD Demuxer,0x00800201,1,2,SonicHDDemuxer.dll,4.02.0000.0061
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.05.2600.2180
WMT Format Conversion,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
StreamBufferSink,0x00200000,0,0,sbe.dll,6.05.2600.2180
WMT Black Frame Generator,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2749
Indeo® video 5.10 Decompression Filter,0x00640000,1,1,ir50_32.dll,5.2562.0015.0055
WMT Screen Capture filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
Microsoft Screen Video Decompressor,0x00800000,1,1,msscds32.ax,8.00.0000.4487
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.05.2600.2749
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.05.2600.2749
MPEG Layer-3 Decoder,0x00810000,1,1,l3codecx.ax,1.05.0000.0050
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.05.2600.2180
ACELP.net Sipro Lab Audio Decoder,0x00800001,1,1,acelpdec.ax,1.04.0000.0000
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.05.2600.2749
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.05.2600.2749
File Source (Netshow URL),0x00400000,0,1,wmpasf.dll,11.00.5721.5145
WMT Import Filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
DV Splitter,0x00600000,1,2,qdv.dll,6.05.2600.2180
Bitmap Generate,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Windows Media Video Decoder,0x00800000,1,1,wmvds32.ax,8.00.0000.4487
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.05.2600.2749
Windows Media Video Decoder,0x00800000,1,1,wmv8ds32.ax,8.00.0000.4000
WMT VIH2 Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Record Queue,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Canon MDP Motion-JPEG Decoder,0x00200001,1,1,CanonMDPMJPEGDecoder.ax,1.00.0000.0002
Windows Media Multiplexer,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASX file Parser,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASX v.2 file Parser,0x00600000,1,0,wmpasf.dll,11.00.5721.5145
NSC file Parser,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ACM Wrapper,0x00600000,1,1,quartz.dll,6.05.2600.2749
Windows Media source filter,0x00600000,0,2,wmpasf.dll,11.00.5721.5145
Video Renderer,0x00800001,1,0,quartz.dll,6.05.2600.2749
Frame Eater,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.05.2600.2180
Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.05.2600.2180
Video Port Manager,0x00600000,2,1,quartz.dll,6.05.2600.2749
WST Decoder,0x00600000,1,1,wstdecod.dll,5.03.2600.2180
Video Renderer,0x00400000,1,0,quartz.dll,6.05.2600.2749
Canon Image Rotation Filter,0x00200000,1,1,CanonRotateFilter.dll,1.00.0000.0009
DivX Decoder Filter,0xff800000,1,1,divxdec.ax,6.06.0001.0004
WM ASF Writer,0x00400000,0,0,qasf.dll,11.00.5721.5145
WMT Sample Information Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,5.03.2600.2180
Microsoft MPEG-4 Video Decompressor,0x00800000,1,1,mpg4ds32.ax,8.00.0000.4487
DivX Demux,0x00600000,1,0,DivXMedia.ax,0.00.0000.0028
File writer,0x00200000,1,0,qcap.dll,6.05.2600.2180
WMT Log Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Virtual Renderer,0x00200000,1,0,wmm2filt.dll,2.01.4026.0000
DVD Navigator,0x00200000,0,2,qdvd.dll,6.05.2600.2180
Sonic Cinemaster® Audio Decoder 4.2,0x008f0001,1,1,CinemasterAudio.dll,4.02.0000.0102
Overlay Mixer2,0x00400000,1,1,qdvd.dll,6.05.2600.2180
AVI Draw,0x00600064,9,1,quartz.dll,6.05.2600.2749
.RAM file Parser,0x00600000,1,0,wmpasf.dll,11.00.5721.5145
WMT DirectX Transform Wrapper,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
G.711 Codec,0x00200000,1,1,g711codc.ax,5.01.2600.0000
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.05.2600.2180
DV Video Decoder,0x00800000,1,1,qdv.dll,6.05.2600.2180
RealPlayer Transcode Filter,0x00600000,0,0,rdsf3260.dll,6.00.0012.1791
Indeo® audio software,0x00500000,1,1,iac25_32.ax,2.00.0005.0053
Windows Media Update Filter,0x00400000,1,0,wmpasf.dll,11.00.5721.5145
ASF DIB Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF ACM Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF ICM Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF URL Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF JPEG Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF DJPEG Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF embedded stuff Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
DivX Subtitle Decoder,0x00600000,1,1,DivXMedia.ax,0.00.0000.0028
9x8Resize,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WIA Stream Snapshot Filter,0x00200000,1,1,wiasf.ax,1.00.0000.0000
Allocator Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
SampleGrabber,0x00200000,1,1,qedit.dll,6.05.2600.2180
Null Renderer,0x00200000,1,0,qedit.dll,6.05.2600.2180
WMT Virtual Source,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
WMT Interlacer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Sonic HD Nav,0x00200000,0,5,SonicHDNav.dll,4.02.0000.0023
StreamBufferSource,0x00200000,0,0,sbe.dll,6.05.2600.2180
Smart Tee,0x00200000,1,2,qcap.dll,6.05.2600.2180
Overlay Mixer,0x00200000,0,0,qdvd.dll,6.05.2600.2180
RealPlayer Audio Filter,0x00200000,1,1,rdsf3260.dll,6.00.0012.1791
AVI Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2749
Uncompressed Domain Shot Detection Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.05.2600.2749
QuickTime Movie Parser,0x00600000,1,1,quartz.dll,6.05.2600.2749
Wave Parser,0x00400000,1,1,quartz.dll,6.05.2600.2749
MIDI Parser,0x00400000,1,1,quartz.dll,6.05.2600.2749
Multi-file Parser,0x00400000,1,1,quartz.dll,6.05.2600.2749
File stream renderer,0x00400000,1,1,quartz.dll,6.05.2600.2749
XML Playlist,0x00400000,1,0,wmpasf.dll,11.00.5721.5145
Sonic Cinemaster® VideoDecoder 4.2,0xffff0000,2,2,CinemasterVideo.dll,4.02.0000.0140
AVI Mux,0x00200000,1,0,qcap.dll,6.05.2600.2180
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.05.2600.2749
File Source (Async.),0x00400000,0,1,quartz.dll,6.05.2600.2749
File Source (URL),0x00400000,0,1,quartz.dll,6.05.2600.2749
WMT DV Extract,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Switch Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Volume,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Stretch Video,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.05.2600.2180
QT Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2749
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.05.2600.2749
psWav Dest,0x00200000,0,0,psWavDes.ax,1.00.0000.0001
Indeo® video 4.4 Decompression Filter,0x00640000,1,1,ir41_32.ax,4.51.0016.0003
Indeo® video 4.4 Compression Filter,0x00200000,1,1,ir41_32.ax,4.51.0016.0003
WDM Streaming Tee/Splitter Devices:
Tee/Sink-to-Sink Converter,0x00200000,1,1,,5.03.2600.2180
WDM Streaming Data Transforms:
Microsoft Kernel Acoustic Echo Canceller,0x00000000,0,0,,
Microsoft Kernel GS Wavetable Synthesizer,0x00200000,1,1,,5.03.2600.2180
Microsoft Kernel DLS Synthesizer,0x00200000,1,1,,5.03.2600.2180
Microsoft Kernel DRM Audio Descrambler,0x00200000,1,1,,5.03.2600.2180
Video Compressors:
WMVideo8 Encoder DMO,0x00600800,1,1,,
MSScreen encoder DMO,0x00600800,1,1,,
WMVideo9 Encoder DMO,0x00600800,1,1,,
MSScreen 9 encoder DMO,0x00600800,1,1,,
DV Video Encoder,0x00200000,0,0,qdv.dll,6.05.2600.2180
Indeo® video 5.10 Compression Filter,0x00100000,1,1,ir50_32.dll,5.2562.0015.0055
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.05.2600.2749
Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.05.2600.2180
DivX® 6.6.1 Codec (2 Logical CPUs),0x00200000,1,1,qcap.dll,6.05.2600.2180
Fraps Video Decompressor,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel 4:2:0 Video V2.50,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel Indeo(R) Video R3.2,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel Indeo® Video 4.5,0x00200000,1,1,qcap.dll,6.05.2600.2180
Indeo® video 5.10,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel IYUV codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft H.261 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft H.263 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft RLE,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft Video 1,0x00200000,1,1,qcap.dll,6.05.2600.2180
XviD MPEG-4 Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
DivX® 6.6.1 YV12 Decoder,0x00200000,1,1,qcap.dll,6.05.2600.2180
Audio Compressors:
WMA Voice Encoder DMO,0x00600800,1,1,,
WM Speech Encoder DMO,0x00600800,1,1,,
WMAudio Encoder DMO,0x00600800,1,1,,
IAC2,0x00200000,1,1,quartz.dll,6.05.2600.2749
IMA ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.2749
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.2749
ACELP.net,0x00200000,1,1,quartz.dll,6.05.2600.2749
DSP Group TrueSpeech(TM),0x00200000,1,1,quartz.dll,6.05.2600.2749
Windows Media Audio V1,0x00200000,1,1,quartz.dll,6.05.2600.2749
Windows Media Audio V2,0x00200000,1,1,quartz.dll,6.05.2600.2749
GSM 6.10,0x00200000,1,1,quartz.dll,6.05.2600.2749
Messenger Audio Codec,0x00200000,1,1,quartz.dll,6.05.2600.2749
Microsoft G.723.1,0x00200000,1,1,quartz.dll,6.05.2600.2749
CCITT A-Law,0x00200000,1,1,quartz.dll,6.05.2600.2749
CCITT u-Law,0x00200000,1,1,quartz.dll,6.05.2600.2749
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.05.2600.2749
Audio Capture Sources:
Realtek HD Audio input,0x00200000,0,0,qcap.dll,6.05.2600.2180
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.05.2600.2749
Microsoft GS Wavetable SW Synth,0x00200000,1,0,quartz.dll,6.05.2600.2749
MPU-401,0x00200000,1,0,quartz.dll,6.05.2600.2749
WDM Streaming Capture Devices:
,0x00000000,0,0,,
,0x00000000,0,0,,
ASUS GSB,0x00200000,0,1,,5.03.2600.2180
WDM Streaming Rendering Devices:
,0x00000000,0,0,,
Realtek HD Audio output,0x00200000,2,1,,5.03.2600.2180
BDA Rendering Filters:
BDA IP Sink,0x00200000,1,1,,5.03.2600.2180
WDM Streaming Mixer Devices:
Microsoft Kernel Wave Audio Mixer,0x00000000,0,0,,
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,0,encdec.dll,6.05.2600.2180
Encrypt/Tag,0x00200000,0,0,encdec.dll,6.05.2600.2180
XDS Codec,0x00200000,0,0,encdec.dll,6.05.2600.2180
WDM Streaming Communication Transforms:
Audio Renderers:
Realtek HD Audio output,0x00200000,1,0,quartz.dll,6.05.2600.2749
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.05.2600.2749
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.05.2600.2749
DirectSound: Realtek HD Audio output,0x00200000,1,0,quartz.dll,6.05.2600.2749
WDM Streaming System Devices:
MPU-401,0x00200000,3,2,,5.03.2600.2180
Realtek HD Audio input,0x00200000,4,1,,5.03.2600.2180
Realtek HD Audio output,0x00200000,12,1,,5.03.2600.2180
BDA Receiver Components:
BDA Slip De-Framer,0x00600000,1,1,,5.03.2600.2180
What voltage does that RAM need? Some chipsets can't supply high enough voltages for high-performance RAM unfortunately. That number of errors is definitely not right though.
Well I bought it from here and looking at the description on the website it says: 1.9V-2.3V Power Supply
Is that what you mean?
This system was pre-built from a computer shop so I have no clue really to what motherboard i have in or what it can take.
I also have to add; other than the crashes in games and the lock-ups in photoshop, the computer runs A LOT faster. The crashes have not happened in-game for awhile now so it might have subsided on that end. Is it possible RAM needs time to 'adjust' to its new configuration?
Most of the time it locks up unexpectedly when I am painting in photoshop with a Wacom Tablet. I have also done a stability test with the application that comes with the nvidia drivers, and it closes down after some time.
Here is my motherboard specs:
775Dual-VSTA
1. LGA 775 for Intel® Core™ 2 Duo/ Pentium® XE / Pentium® D / Pentium® 4 / Celeron® D processors
2. VIA® PT880 Pro/Ultra Chipset
* Supports FSB1066/800/533MHz processor, EM64T CPU and H-T Technology
* Supports Dual Channel DDRII667 (DDRII x 2 DIMMs) and DDR400 (DDR x 2 DIMMs)
* Untied Overclocking : During Overclocking, FSB enjoys better margin due to fixed AGP/PCIE/ PCI Buses
* 1 x PCI Express Graphics slot
* 1 x AGP 8X slot
* Hybrid Booster - Safe Overclocking Technology
* 2 ports of SerialATA 1.5Gb/s, support RAID 0, 1, JBOD, 2 ATA133 IDE ports
* HDMI_SPDIF header, providing SPDIF audio output to HDMI VGA card, allows the system to connect HDMI Digital TV/projector/LCD devices.
* 7.1 channel with High Definition Audio, 10/100 Ethernet LAN
* Supports all features in Vista™ Premium
* HD 8CH I/O: 4 ready-to-use USB2.0 ports, HD 7.1 channel audio jacks
Does this mean it is incompatible? In BIOS it says my RAM is doing 533. Or does the DDRII667, equal the 800 for the RAM I bought? It does explain the unexpected crashes...
Hey guys, I am 99.99% certain that i accidently bought the wrong RAM. So I have already placed my order for the 667MHz and in the process of returning the unwanted RAM.
Thanks for helping me realise the mistake.
