Crashing woes...
Man of Honour
18 Oct 2002
Got a PC to sort out here - Every component checks out in another machine which is annoying me.
I suspect there's something with the graphics card going on - It's a Sapphire 4870 512mb bog standard card.
In 3d apps *I'm testing with Fallout 3* after an unpredictable amount of time, sometimes under 5 minutes - sometimes over an hour, screen goes black, sound crashes and loops, and the PC eventually reboots.
In 2d - it's fine.
Power usage is way below what the power supply can provide.
CPU temps are fine...
GPU temps are fine... Set the fan to 100% and the cpu and memory speeds to the 3d settings to prevent the speed bump happening.
Tried Catalysts from 8.6 to 9.5 - same thing happens in all.
Stumped...
Error reports that I have actually got out of the machine points to Ati2mtag.sys - the driver.
Tried the Catalyst AI in on, off and advanced - no difference
Google seems to be no help. Only thing I can think of it's that it's something to do with the machine running XP64...
Any ideas?
I remember having a similar problem with an older GPU and XP64. The screen would freeze and the sound would loop. After loosing a lot of hair due to the problem l have found that my Audigy 2 was causing the trouble.
I would upgrade to Vista 64bit if l were you. The fact that the card works fine on your second PC suggests that making the jump to a new OS would be the best option.
