***** CRAZY IIYAMA i49 LAN DEALS!! *****
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
To celebrate i49 LAN iiyama have given us some uber crunchy deals:-
Iiyama Prolite E2773HS-GB1 27" Widescreen LED 1MS Monitor - Black @ £179.99 inc VAT
The LED-backlit ProLite E2773HDS 27” LCD Display features a stunning 1 ms Response Time and a High Definition 1920 x 1080 Resolution. The 5 000,000:1 Advanced Contrast Ratio and 300 cd/m² brightness offer the user clear and vivid images, and the HDMI, DVI and D-Sub connections ensure compatibility across a range of devices including games consoles and work stations. The display is Windows® 7 Compatible and Energy Star® 5.0 qualified.
Features:
- LED Backlit
- Full HD
- ACR Capeablity
- Inbuilt Speakers
- HDMI Input
- Overdrive Feature
- VESA Mountable
- Compatible with Xbox 360 & PS3
Technical Specifications:
- Screen Size: 27" Widescreen
- Resolution: 1920x1080
- Contrast Ratio: 5 000 000 : 1
- Brightness: 300cd/m²
- Response Time: 1ms
- Viewing Angles (H/V): 170°/160°
- Colours: 16.7 Million
- Inputs: 1x Analogue, 1x DVI-D & 1x HDMI
- VESA Compliant
- Adjustable Stand
- Dimensions: 561.0mm x 413.5mm - 523.5mm x 249.0mm
- Weight: 5.3kg
- Warranty: 3 Years On-Site
Was [£259.99] Inc. VAT
Only £179.99 inc VAT.
ORDER NOW
IIyama Prolite E2473HS 24" Widescreen LED Monitor - Black @ £133.99 inc VAT
The ProLite E2473HDS LED-backlit monitor, finished in the latest glossy-black, is a full high definition 24" display that features all the benefits this technology affords. The high specifications of the monitor include the 5,000,000:1 ACR, triple input connectivity (D-Sub, DVI-D, 2 x HDMI) and fast 2ms response for excellent sharpness in high definition video. VESA mount compatibility along with one HDMI input and headphone connector on the side of the cabinet ensures great comfort of usage.
Features:-
- Diagonal: 23.6"
- Panel: LED-Backlit
- Display area: h x w 293.2 x 521.3 mm; 11.54" x 20.51"
- Response time: 2 ms
- Contrast: 1000 : 1 typical
- Contrast: 5 000 000 : 1 ACR
- Brightness: 300 cd/m² typical
- Connections: D-Sub, DVI-D & 2x HDMI
- Viewing zone: horizontal/vertical: 170°/ 160°; right/left: 85°/ 85°; up/down: 80°/ 80°
- Display colour: 16.7 million
- Pixel pitch: h x v 0.2715 x 0.2715 mm
- Native resolution: Full HD 1080p, 1920 x 1080 ( 2.1 megapixel)
- Horizontal sync: 24 - 80 KHz
- Vertical sync: 55 - 75 Hz
- Synchronization: Separate sync
- Aspect ratio: 16 : 9
- 3yr On-site Warranty
Was [£169.99] Inc. VAT
Only £133.99 inc VAT.
ORDER NOW
Iiyama Prolite E2481HS-B1 24" Widescreen LED Super Slim Bezel Monitor - Black @ £139.99 inc VAT
The ProLite E2481HS is a 24’’ Full HD 1920 x 1080p LED-backlit monitor with super slim (7 mm) bezel. It features 2ms response time and >5 000 000 : 1 Advanced Contrast Ratio assuring clear and vibrant picture quality. Triple Input support of Analogue, DVI and HDMI ensures compatibility with the latest installed graphics cards and embedded notebook outputs. The monitor is Energy Star and TCO Certified. A reliable solution for all kind of work environments where best performance is desired.
A typical CCFL LCD uses four backlight lamps. Using LED diodes considerably lowers the power consumption and reduces the CO2 emission into the environment making this LCD a true ECO-Friendly product. With true 1920 x 1080p resolution your monitor is ready to display high definition images. This means you can accommodate more information on your screen; e.g. 60% more in comparison to a 1280 x 1024 monitor. Contrast Ratio is a measurement of the difference between the darkest black and the brightest white your monitor can display. Advanced Contrast Ratio is a feature that automatically adjusts contrast and brightness of the screen to assure perfect picture quality while watching films and playing games. This LED monitor is equipped with two high quality stereo speakers. HDMI stands for High-Definition Multimedia Interface. Much smaller and more convenient than DVI, HDMI also has the significant advantage over DVI that it supports audio as well as video signals. When very fast graphics are displayed your monitor can sometimes get blurry. Turning on the OverDrive feature will eliminate that. VESA mount compliance means you can easily mount your monitor to a wall.
Specification:-
- Diagonal: 23.6"
- Panel: TN, LED-Backlit
- Display area h x w: 293.22 x 521.28 mm; 11.5" x 20.5"
- Brightness: 250 cd/m² typical
- Viewing zone: horizontal/vertical: 178°/ 170°; right/left: 89°/ 89°; up/down: 85°/ 85°
- Pixel pitch h x v: 0.2715 x 0.2715 mm
- Vertical sync: 56 - 75 Hz
- Input connections: VGA, DVI-D & HDMI
- Speakers: 2 x 2 W (Stereo)
- Anti-theft-device: Kensington-lock™ prepared
- Certificates: CE, CU, TUV-GS, TCO
- Tilt angle: 21° up; 4° down
- VESA mounting: 100 x 100 mm
- Warranty: 3yr
Was [£155.99] Inc. VAT
Only £139.99 inc VAT.
ORDER NOW
Iiyama Prolite E2482HSD 24" Widescreen LED Monitor - Black @ £119.99 inc VAT
The ProLite E2482HSD is a 23.6” Full HD eco friendly LED monitor. The product complies to TCO and Energy star making it the right choice for eco conscious customers. The 5ms Response Time and >5mln:1 Advanced Contrast Ratio panel ensures vibrant images and blur free Video. DVI and VGA inputs guarantee compatibility with the flexibility to switch between multiple sources. The ProLite E2482HSD comes equipped with two 2W Stereo speakers.
Features:-
- Diagonal: 23.6"
- Panel: TN LED-Backlit
- Response time: 5ms
- Contrast:1000:1 typical
- Contrast: 5 000 000:1 ACR
- HDCP: Yes
- VESA: 100x100mm
- Stereo Speakers
Was [£139.99] Inc. VAT
Only £119.99 inc VAT.
ORDER NOW
IIyama Prolite E2273HDS 22" Widescreen LED Monitor - Black @ £115.99 inc VAT
The ProLite E2273HDS is a LED-backlit monitor. It is a full 1920x1080 high definition 22” display that features all the benefits this technology affords. Extremely slim and stylish in design, it has a narrow bezel and is finished in the latest glossy-black. The high specifications of the monitor include 5,000,000:1 ACR, fast 2ms response for excellent sharpness in high definition video and triple input connectivity (including HDMI). Power consumption is only 21W typical usage and 0,5W in standby.
With true 1920 x 1080p resolution your LCD is ready to display any high definition images. It also offers you much more viewable area than a standard LCD with 1280 x 1024 resolution.
Contrast Ratio is a measurement of this difference between the blackest black and the whitest white your LCD can display. Advanced Contrast Ratio is a feature that automatically adjusts the contrast and brightness based on the darkness of the image. The higher the ratio, the better your screen will look when you have the lights off in a room.
Features:-
- LED Backlit
- Screen Size: 22" Widescreen
- Contrast Ratio: 5000000:1
- Response Time: 2ms
- Inputs: 1 x Analogue, 1 x DVD-D, & 1 x HDMI
- Dimensions: 268.1 x 476.6 mm; 10.6" x 18.8"
- Weight: 2.9kg
Was [£129.95] Inc. VAT
Only £115.99 inc VAT.
ORDER NOW
These iiyama deals end on Tuesday, some cracking monitors there to go with the amazing graphics deals we've being doing and still are doing. :)
Shame these don't have free delivery and/or weren't on offer when I got my 680 the other week :( Great prices otherwise :)
Oooh that's some good prices! Was gunna wait until September until I ordered a monitor but . . .
Damn it ocUK, I was quite happily waiting until payday for a 24", how I am supposed to pass up that 27! :D
I got two Iiyama 23" IPS Monitors ...and I only use the left hand side one for my games ( if they let me run on monitor 2 ) and my game desktop icons
A friend of mine paid £250-ish for the older model of the 27" last year. The first thing I saw running on it was BF3 and it was stunning. I thought the image might suffer due to the res at that size but having such a large screen area helped draw you in to the game.
Wish I could have got one at this price but I will have to drop hints to my wife for a birthday/Christmas pressie at the end of the year.
@FARGO: Nope, the 27" is only a 60hz panel but still a very nice screen. I have been a fan of Iiyama screens since the days of selling CRT monitors (I always went Iiyama or Mitsubishi IIRC).
Is there any need to take 1080p upto 27"?! With a monitor (which you sit much closer to than a TV), I think I'd want more screen estate at that size, not for gaming but for the whole host of other things!
Only just binned my old Iiyama Visionmaster Pro 452 a few weeks back (it wasn't used and needed the space!).
The miser in me wouldn't let me buy one. Great work on securing those prices though!
I wish I could see in to the future so that I could put some money aside for such things. Perhaps now and then OCUK could give a few weeks notice on selected deals so that people like me can clear the moths out the wallet! :p
