Hi,
I recently bought a ASUS H81M-K. Everything is running fine, except I am getting some very strange temp readings.
My GPU and CPU are both reporting idle temps of about 25c - 30c.
However, in HWMonitor for the MB it lists:
SYSTIN 123c
TZ01 30c
CPUTIN 27c
TMPIN3 29c
Speccy reports MB as the same as SYSTIN, so 123c.
In Open Hardware Monitor, for the MB it lists:
Cpu Core: 29c
Temp 1: 27c
Temp 2: 123c
Temp 3: 44c
Temp 4: 115c
Temp 5: 115c
Temp 4: 45c
Anyone know what's going on?
I'm assuming I'm looking at faulty readings, as otherwise the MB would be melting. Also, the temps are at this level immediately upon turning the machine on, when even the GPU and CPU are barely out of the teens.
I don't even understand the lower temps of around 45, because surely the hottest parts will be near the CPU / GPU, and these are idling at about 25?!
SYSTIN 123c
TZ01 30c
CPUTIN 27c
TMPIN3 29c
Cpu Core: 29c
Temp 1: 27c
Temp 2: 123c
Temp 3: 44c
Temp 4: 115c
Temp 5: 115c
Temp 4: 45c
