- 19 Sep 2019
Hi , trying to set my system to limit power to be used as a server , but with auto and all default pbo with proxmox with a windows 10 vm and 12 cores the wattage goes from 55-60 idle to 180 Watts on a 240mm aio , to me this is way too high for default all auto but ram speed .
try the Curve Optimizer -40mv which make it run at 65c , 180 + Watts .
also instead of pushing the 12 cores to the max , I put a 50% load all it does is up the clocks and run at 180 Watts from the wall.
