** CRAZY PRICE: KINGSTON 3000MHz DDR4 KIT!! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
Kingston have some of the best performance DDR4 and our pricing on them puts our competitors to shame, even better we have 100's of them in stock:-
Kingston Predator 16GB (4x4GB) DDR4 PC4-24000C15 3000MHz Quad Channel Kit - Black (HX430C15PB2K4/16) @ £259.99 inc VAT
Kingston Predator DDR4 is some of the most aggressive looking DDR4 available and looks menacing. Make your opponents fear you with Kingston Predator DDR4.
Specification:-
- CPU Compatibility: Intel Haswell-E ( LGA 2011-3 )
- Chipset: Intel X99
- Capacity: 16GB (4GBx4)
- Quad Channel kit: Yes
- Tested Speed: DDR4-3000 MHz (PC4-24000)
- Tested Latency: 15-15-15-35
- Tested Voltage: 1.25V
- Registered/Unbuffered: Unbuffered
- Error Checking: Non-ECC
- Type: 288-pin UDIMM
- SPD Speed: 2133 MHz
- SPD Voltage: 1.2V
- Features: Intel XMP 2.0(Extreme Memory Profile)Ready
- Warranty: Lifetime
Was [£269.99] Inc. VAT
Only £259.99 inc VAT.
ORDER NOW
UK's Largest DDR4 Range IN STOCK - CLICK HERE!
You are right, it IS crazy to charge £260 for 16gb of ram.
Yeah if you have no grasp on the memory market. You know not all 16gb kits are the same?
Respectively speaking this is less than Team Group were asking for DDR3 2666 kits a few months ago.
Not sure what you want? There are plenty of cheap 16gb kits available, they're just slower...
If you want slower that's your prerogative :p
Gibbo, are the numbers right on that listing?
I was looking at this ram as an option and on the Kingston PDF it shows DDR4-3000 CL15-16-16 @1.35V
http://www.kingston.com/datasheets/HX430C15PB2K4_16.pdf
Is the following what you have tested them at or just an error somewhere?
Thanks!
Fixed mate, actually tested them as low as 13-14-14-31 with 1.35v at 3000MHz, good kits. :)
Just for you:-
Crucial 16GB (4x4GB) DDR4 PC4-17000C16 2133MHz Quad Channel Kit (CT4K4G4DFS8213) @ £146.99 inc VAT
In the ever-changing world of technology, any component more than half a decade old is usually in need of an update. At seven years old and counting, that’s exactly the state DDR3 memory is in: computers can only do so much with it.
Since the introduction of DDR3 memory technology in 2007, processors have doubled in capability, SSDs have revolutionized throughput, and graphics cards have drastically increased frame rates, leaving memory as a limiting factor. With Crucial DDR4 Desktop Memory, crush the DDR3 memory bottleneck and unlock a new standard of performance.
Load applications faster and run demanding programs without lag. Crucial DDR4 memory debuts at 2133 MT/s – more than 30% faster than DDR3 memory technology.1 Even better, as DDR4 technology matures, speeds are projected to hit 3200 MT/s – twice what was possible on standard DDR3 memory.
Effortlessly multitask between apps, and empower your system to fire on all cylinders. Crucial DDR4 increases memory bandwidth by over 30%, allowing your system to handle more data at once. As DDR4 technology matures, bandwidths are expected to achieve up to 25.6 GB/s – twice that of standard DDR3. To maximize bandwidth, Crucial DDR4 memory is optimized for nextgen platforms that support four channel memory.
Get better performance – using less power. Operating at just 1.2V compared to 1.5V for standard DDR3 memory, Crucial DDR4 consumes 20% less voltage than standard DDR3 technology. Crucial DDR4 modules also contain other efficiency features, for an overall power reduction of up to 40%.
As a brand of Micron, one of the largest memory manufacturers in the world, Crucial DDR4 memory represents the future of computer performance. From the original DDR technology to DDR4, we’ve engineered the memory technologies that have powered the world’s computers for 35 years and
counting. When you choose Crucial DDR4 memory, you’re choosing memory that’s backed by a limited lifetime warranty2 and designed for the world’s leading systems. Don’t settle for anything less.
Specification:-
- 2133MHz (PC4-17000)
- CAS Timings: 16-16-16
- Voltage: 1.20v
Only £146.99 inc VAT.
ORDER NOW
No more than a DDR3 kit. :)
Our prices are superb on that 3000MHz kit and the sales are proving that selling nearly 10 kits a day. :)
G.Skill is a rip off to be honest, they are taking the mick, shipping low quantities and keeping pricing high, jokers they are.
Thanks for the info, just trying to find good quality and staying away from corsair.
do the tall heat spreaders come off?....are they they too tall for a nh-d15
edit
spec sheets suggest they fit
height 55mm
http://media.kingston.com/pdfs/HX_Predator_DDR4_EN.pdf
nh-d15 clearence=64mm
http://www.noctua.at/main.php?show=c...s_id=68&lng=en
They only fit 64mm clearance if you run the NH-D15 in single fan mode otherwise you have to move the second fan out the way but only if you have enough case clearance!
Which I nearly got caught out by, but luckily stulid was here to point me in the right direction!
