Hi there
Some truly exceptional deals here on some truly exceptional monitors from BenQ:-
BenQ G2222HDL 21.5" Widescreen LED Monitor - Black @ £99.95 inc VAT
The BenQ LED monitors come with an ultra-high dynamic contrast ratio of 5000000:1 to add colour depth and definition to darkened and complex visuals, so that everything you see - from the brightest white to the darkest black - is perfectly rendered to deliver the most incredible picture performance. The G2222HDL provides true-to-life 16:9 images that fit the 1920x1080 resolution perfectly. It offers outstanding image quality and a clear view of multiple documents simultaneously to ensure the highest work productivity. With a speedy 5ms response time, even highly dynamic video is rendered with smooth, fluid motion without ghosting or other artifacts to distract your view.
- LED Backlit
- Screen Size: 22" Widescreen
- Resolution: 1920x1080
- Contrast Ratio: 5000000:1
- Brightness: 250cd/m²
- Response Time: 5ms
- Viewing Angles (H/V): 170°/160°
- Colours: 16.7 Million
- Inputs: 1x Analogue & 1x DVI-D
- VESA Compliant
- Dimensions: 504.6mm x 392.9mm x 175.0mm
- Weight: 3.8kg
- Warranty: 2 Years On-Site
Was [£109.99] Inc. VAT
Only £99.95 inc VAT.
ORDER NOW
BenQ RL2240H 22" Widescreen LED Monitor - White @ £109.99 inc VAT
The RL2240H is a professional gaming monitor suited for RTS game play. Co-designed with the renowned StarCraft II team, StarTale, this 21.5” LED backlight monitor is packed with the latest features: the Black eQualizer, RTS mode, Display mode, Smart Scaling, 2ms GTG, HDMI and 12M:1 dynamic contrast ratio.
Built to set the benchmark for RTS gaming monitors, the RL2240H is a true testament to the belief that 'gaming is in the details'. Each and every feature has been meticulously thought out and created together with the renowned StarCraft II team, StarTale, to provide RTS gamers with vital visibility and command to take their performance to new heights.
The collaboration successfully brought together prominent players from StarTale and tapped into their wealth of knowledge and insights to create the ultimate gaming monitor that can handle real-time strategy games. Professional gamers like Rainbow, July, Ace, Bomber, Squirtle and Virus provided BenQ with insider perspectives on details that were essential to winning a game. The recent achievements from individual StarTale gamers include winning Clash of the Houses, IEM World Championship, Intel Extreme Masters Season 5 and GSTL league play.
The Black eQualizer is an exclusive feature that meets the demands of gamers when it comes to unprecedented level of control and visibility. Via finely designed color engine technology, dark scenes are brightened without over-exposing white levels, allowing gamers to acquire critical combat details and information and react quickly. Don’t let poor visibility and judgment cost you the game.
During product development and testing stages, BenQ's product team and the StarTale players exchanged several visits to fine-tune the display performance of the RL2240H for better accessibility and comfort. What they came up with is the preset RTS mode that automatically adjusts your monitor calibrations accordingly for optimum RTS gaming. This out-of-the-box setting allows you to see your enemies more visibly among the distractions and darkened areas. See what the professional gamers see and get the competitive edge you need with optimized color and contrast exposures. The exclusive preset RTS Mode will be your ultimate secret weapon.
The Display Mode and Smart Scaling features allow you to change the monitor view to suit your liking and to simulate any in-game experience. Interchange instantly between four different screen sizes from 17", 19" and 19"W to 21.5" using the Display Mode. Or take advantage of the Smart Scaling feature and enjoy the flexibility to freely scale the screen content to any custom size. You can certainly use the two features together to get the best possible view for any application or game.
Fast response time of 2ms GTG means speed without the smear. Fast-moving action and dramatic transitions will be rendered smoothly - without smearing or ghosting. Control your gaming destiny and don’t leave it in the hands of sluggish display.
The RL2240H comes in a sleek white housing that was favored by StarTale_July. Be the envy of all the other gamers as you sport the RL2240H with fluid lines and distinct curves.
Features:-
- Screen Size: 21.5”W
- Aspect Ratio: 16:9
- Resolution (max.): 1920x1080
- Brightness ( typ.): 250 cd/m2
- Contrast ( typ. ): 1000:1
- DCR (Dynamic Contrast Ratio) (typ.): 12M:1
- Viewing Angle (L/R;U/D) (CR>=10): 170/160
- Response Time(Tr+Tf) typ: 2ms GTG
- D-sub/DVI/HDMI/Headphone Jack
- 2yr Warranty
Was [£119.99] Inc. VAT
Only £109.99 inc VAT.
ORDER NOW
BenQ G2420HDBL 24" Widescreen LED Monitor - Black @ £131.99 inc VAT
The BenQ LED monitors come with an ultra-high dynamic contrast ratio of 5000000:1 to add colour depth and definition to darkened and complex visuals, so that everything you see - from the brightest white to the darkest black - is perfectly rendered to deliver the most incredible picture performance. The G2420HDBL provides true-to-life 16:9 images that fit the 1920x1080 resolution perfectly. It offers outstanding image quality and a clear view of multiple documents simultaneously to ensure the highest work productivity. With a speedy 5ms response time, even highly dynamic video is rendered with smooth, fluid motion without ghosting or other artifacts to distract your view.
- LED Backlit
- Screen Size: 24" Widescreen
- VESA Compliant
- Dimensions: 570.0mm x 412.6mm x 183.9mm
- Weight: 4.4kg
Was [£199.99] Inc. VAT
Only £131.99 inc VAT.
ORDER NOW
Benq XL2410T 24" TRUE 120Hz 3D Widescreen LED Monitor - Black @ £249.95 inc VAT
BenQ, proudly announced the release of their 23.6” (16:9 Aspect Ratio) LED Gaming Monitor XL2410T. BenQ understands that to lead and become a true and professional gaming monitor provider, they have to understand the mindset and needs of gamers. In order to achieve this goal, BenQ co-worked with ZOWIE, a professional Gaming gear manufacturer. BenQ have ZOWIE’s gamer teams join in during the product development and testing stages. With their assistance, XL2410T can truly be a professional LED gaming monitor – with a set of Gaming Display Modes which includes the FPS mode (First Person Shooting), co-developed by two legendary Counter-Strike players – Emil “HeatoN” Christensen and Abdisamad “SpawN” Mohamed.
Every serious gamer know that lag will cause you to lose a game; XL2410T is made to have a quick response to action, hardware lag will no longer be the cause for your headshots. XL2410T has a fast refresh rate of 120Hz for higher precision; a low input lag so the shots made is more in sync with the visual on-screen; a quick 2ms GTG (OverDrive) meaning users can see the edge of the enemies clearly and without motion blur, and Dynamic Contrast Ratio of 10,000,000:1 for detailed images and clarity in both darkened and brightened situations, this complemented with BenQ’s gaming tuning technology becomes a huge advantage for gamers.
XL2410T has a smart design, for one purpose – to win. The monitor has two hotkeys available; the first changes the display mode: Full; Aspect; Overscan; 1:1; 17”; 19”; 19” Widescreen and 22” Widescreen. Whereas the second hotkey is Smart Scaling, which lets the users adjust picture size in original input to the screen’s limit. Together with Display Mode function, users can play in the resolution size they are used to with their previous monitor, or adjust their screen size to what their teammates are using for easier communication and reference. From BenQ’s Gaming Display Modes options, users can choose from FPS Mode, made possible by co-working with the gaming heroes -HeatoN and Spawn as the best setting for personal shooting games, or from the two User Game modes for more dedicated and personalized settings.
For extreme entertainment, XL2410T is the LED monitor to go for. 3D-ready (NVIDIA 3D Vision certified); Picture by Picture (PBP); connectivity values (D-sub; DVI-D-DL, HDMI) and height adjustment feature are offered for users’ enjoyment and comfort. Picture by picture (PBP) is a feature that enables users to show two programs side-by-side on the screen. Feel like camping once in a while for fun? Watch a movie while you do it!
- LED Backlit
- Screen Size: 23.6" Widescreen
- Contrast Ratio: 10000000:1
- Brightness: 300cd/m²
- Response Time: 2ms
- Inputs: 1x Analogue, 1x DVI-D & 1x HDMI
- VESA Compliant
- Weight: 6.0kg
- Height adjustable stand / Swivel 45/45 left/right
Was [£269.99] Inc. VAT
Only £249.95 inc VAT.
ORDER NOW
BenQ G2750 27" Widescreen LED Monitor - Black @ £175.99 inc VAT
An enjoyable addition to your everyday home or work life, the G2750 gives you crisp and accurate viewing at all times. The G2750 comes with a dynamic contrast ratio of 50000:1 to add color depth and definition to darkened and complex motion pictures, so that everything you see, from the brightest white to the darkest black, is perfectly rendered to deliver the clearest, smoothest picture performance during movies and video games. The G2750 supports the Full HD 1080p with 16:9 aspect ratio - allowing the subtlest details to stand out with richer, more realistic colors, making your viewing experience even more absorbing. Experience the truest colors of the world with the BenQ Senseye® Human Vision Technology. With the help of its six proprietary calibration techniques, Senseye® 3 delivers only the best viewing quality in each of its six pre-set viewing modes –Standard, Movie, Game, Photo, sRGB, and Eco – with the Eco Mode especially designed to save power and money. The G2750 has passed Windows® 7 certification and are fully compatible with Windows® 7 color systems. Plug in the G2750 to your computer, and Windows 7 will recognize it instantly, making setup and connection effortless.
- Screen Size 27"W
- Resolution (max.) 1920 x 1080
- Pixel Pitch 0.276 mm
- Brightness 300 cd/m2
- Contrast Ratio 1200:1
- DCR:50,000:1
- Response Time (tr/tf) 5 ms
- Display Area 597.6 x 336.15 mm
- Display Color 16.7 million
- Viewing Angle (L/R;U/D) (CR>=10) 170 / 160
- Terminals D-sub / DVI-D
- Horizontal Frequency (Max) KHz 30 ~ 83
- Vertical Frequency (Max)Hz 50 ~ 76
- Video Bandwidth (MHz) 205
- Colour Temperature Reddish / Normal / Bluish / User mode
- Power Consumption 52W (max)
- Auto Switching Power Supply Built-in
- Features Senseye® Human Vision Technology (plus Senseye 3)
- HDCP Support
- OSD Language: 17 languages
- Windows 7® compatible
- K locker: yes
- Adjustments Tilt (down / up) -5 / 15
- Dimensions (HxWxD) 488.5 x 654.4 x 191.2 mm
- Weight Net weight: 6.4 kg.
- Gross weight: 8.12 kg.
- Accessories (Standard) VGA
- Product Colour Glossy Black
- Vista Certification Premium
- VESA Wall Mounting 100 x 100 mm
- 2yr Warranty
Only £175.99 inc VAT.
ORDER NOW
- LED Backlit
- VESA Compliant
- Weight: 3.8kg
ORDER NOW
Features:-
- 2yr Warranty
ORDER NOW
- LED Backlit
- VESA Compliant
- Weight: 4.4kg
ORDER NOW
- LED Backlit
- VESA Compliant
- Weight: 6.0kg
ORDER NOW
- Screen Size 27"W
- DCR:50,000:1
- HDCP Support
- K locker: yes
- 2yr Warranty
ORDER NOW
