Hi guys,
Had a search through here but cannot find exactly what i am looking for. I want something that I can tweak a build of xp with all my installed apps and copy this onto a dvd to use it as a boot disk for reformatting my machines. It would work on the same way that firms would reimage a large amount of machines with a tailor made build.
For instance I would want a build of xp with all the latest service packs + updates. Then other additions like .net framework etc.
Are there any handy tools which allow me to slim down xp installs but always run install scripts for all the apps I want?
Or is it better to install xp manually, install everything I want and then take a snapshot of the current state which can be bootable?
Any recommendations on apps to do this?
