Create/Add files but not modify permissions
3 Nov 2002
Hi, i have a drawings directory on our windows 2003 server, i want to allow users to create/add new files to the directory but not be able to delete or modify... im concerned about accidents happening to our important files.
However i cant seem to find the right settings, as under special permissions tab the Create Files/Write Data allows for modification.
Any pointers so i can achieve this level of security?
Thanks in advance,
Chris
Try playing round with the "Apply onto" option in the special permissions tab. I think if you select "This folder only" you can get the setting you want.
