Hi
I have an old device that I need to setup (a Boxee Box) and it is looking to ping http://x.ping.boxee.tv/ (x being a number between 1 and 9) to test the network connection. I would like to create a network where a ping to that address or any address for that matter simply return a http status of 200 so the box thinks it is connected and I can set it up. Is this possible?
I have ay my disposal a Virgin Super Hub 2.0, a Synology Disk Station NAS, 2 Apple MacBooks, Ethernet cables and I am fairly tech savvy but not when it comes to networking. The Boxee device can connect using WiFi or ethernet.
Any help would be appreciated and I ma happy to look into buying routers etc if it helps.
I have tried connecting the device directly to my MacBook and setting my host file to point http://x.ping.boxee.tv/ to localhost but sharing my internet on ethernet seems to bypass the hosts file. Sharing the internet via wifi also seems to bypass the hosts file.
Thanks in advance.
Thanks in advance.
