Creating a custom resolution
11 Oct 2006
I'm using nVidia CP with my XFX 9700 GS + Samsung 226BW
Im trying to make a frag movie but i cant seem to get my counter-strike to run at 960x600
I can run it with my CRT becasue it supports a ton of resolutions as default... but my LCD simply wont have it
everytime i try to add a custom resolution on nvidia CP it wont have it.. "test failed"
anyone have a clue how to do this?
Thanks.
You could try adding the resolution directly into the driver:
-Extract your driver of choice to a temp directory
-Open up nv4_disp.inf in notepad
-Search for the string "NV_Modes"
-Input your new resolution in there after 640x480
-Save changes to the file and run setup.exe
-Reboot after driver install and see if your new res is available
a tft is never guaranteed to run a resolution that is forced in the drivers though. i know mine doesn't..... :)
(cheap tft here mind. i dare say a decent one would :p)
Thanks buddy, it worked :)
for those of you who asked.. i wanted my movie in widescreen... just not 1600x900 and ive seen a couple others in 960x600
Thanks for the help guys
