HI guys
I have created a database in PhpMyAdmin and would like to create a search feature in my website for users to search for certain things throughout all the tables in the database.
Would like to be able to search by name, date etc.
I have done some research online and found code which i tried to use but couldn't get it working.
When setting up my search form i have set the action to <?=$PHP_SELF?>.
When i run the search i just get a blank page.
Any suggestions folks or even a better method to use.
Thanks
Code:
//This is only displayed if they have submitted the form
if ($searching =="yes")
echo "<h2>Results</h2><p>";
//If they did not enter a search term we give them an error
if ($find == "")
echo "<p>You forgot to enter a search term";
exit;
// Otherwise we connect to our Database
mysql_connect("******", "*****", "*******") or die(mysql_error());
mysql_select_db("******") or die(mysql_error());
// We preform a bit of filtering
$find = strtoupper($find);
$find = strip_tags($find);
$find = trim ($find);
//Now we search for our search term, in the field the user specified
$data = mysql_query("SELECT * FROM ******** WHERE upper($field) LIKE'%$find%'");
//And we display the results
while($result = mysql_fetch_array( $data ))
echo $result['Product'];
echo " ";
echo $result['Date'];
echo "<br>";
echo $result['PassFail'];
echo "<br>";
echo "<br>";
//This counts the number or results - and if there wasn't any it gives them a little message explaining that
$anymatches=mysql_num_rows($data);
if ($anymatches == 0)
echo "Sorry, but we can not find an entry to match your query<br><br>";
//And we remind them what they searched for
echo "<b>Searched For:</b> " .$find;
Thanks
Tho now im getting page cannot be displayed!!
