Hi guys considering my next build for the Q4 CPU releases and am looking to bin my current case and move to an XL, I am particularly taken with the front glass and hidden PSU, and hidden hot-swapping drives for 4 8tb ssds so I think I am locked into this case at this point.
Now I also have an aversion to AIO coolers - after an intensely annoying experience with Swiftech which led me back onto aircooling and i've had a dark rock pro 4 for a few years which has been incredibly silent and looking to reuse that.
Now obviously aircooling in a liquid cooling focussed case is a bit of an issue so wondering would this work:
3 side mounted 120mm silent wings 3 pwm - mounted into a pwm fan splitter into the mobo
3 bottom mounted 120 mm silent wings 3 pwm - mounted into a pwm fan splitter into the mobo
1 rear mounted 120mm silent wings 3 pwm right into mobo
(I have 4 of these fans already)
Now is this potentially too many fans? Would putting 140mm in the bottom be better than three 120s for creating the correct pressure gradient? Should I put some on the top too?
Not too worried about cost just looking for it to be silent.
Graphics card is a 3090 suprim.
Or am I making a mistake on this case for air? There's an alternative in the 7000d airflow but aesthetically it's a plastic mess vs the metal and glass of the lian li.
