- 21 Oct 2008
- Jarrow
I had to stop using the wired Belkin network router and cards I had as there were constant gaps of a 1-10 seconds between data. Everything works perfectly on wired setup.
The cable modem (which is about 5 years old but working perfectly) has the function to connect by USB or ethernet conenctors which is what I use. In order to setup a network for two riggs to share the internet am I just gonna have to buy a wired router, connect it to the modem and run a couple of cables to the two PCs? Or is the hardware setup a bit more complex than that?
