Creating folders outside wordpress
28 Sep 2003
London
i am trying to create a folder on FTP , IE /images
so i can go to www.mydomain.co.uk/images and see the files via the web
however i have wordpress installed and just get 404 error when trying to view the folder
someone mentioned might be a htaccess file problem
here is mine:
this is my htaccess file, not got a clue what to change ?
# BEGIN WordPress
<IfModule mod_rewrite.c>
RewriteEngine On
RewriteBase /
RewriteRule ^index\.php$ - [L]
RewriteCond %{REQUEST_FILENAME} !-f
RewriteCond %{REQUEST_FILENAME} !-d
RewriteRule . /index.php [L]
</IfModule>
# END WordPress
I don't think it should 404 from your htaccess. Are you trying to view the folder from your browser? If you put a file in that folder and access that direct does it still 404?
A lot of hosts will blanket sites with security such as limiting folder display permissions.
Try making a new .htaccess file in your images folder and put the below line in it. Don't amend your root .htaccess.
Code:
Options +Indexes
yes trying to get to folder with a browser.
ill check if a file in there still gives 404
will try that,
thank you
