Creating System Image Problem!!!
14 Oct 2009
UK
I keep getting this problem when i try to make a system image, I got it on both windows system image creater and this program,
What can i do to fix it?
just click ignore, i had same problem with vista. I didnt sort it, it fixed itself after an update of some sort. Never had this problem with W7.
Try unplugging an external HD if you have one.
theres your problem. I dont think its possible to back a system image to a external HD. Try backing it to a drive then moving it over to the external HD if thats possible
