** Creative Bundle Fatal1ty and Soundblaster FX £39.95**
7 Feb 2011
Stoke on Toast
Creative Gamer Bundle Headset and Soundcard @ £39.95 inc VAT
Kick start your Gaming with this bundle from Creative. Featuring Creatives Fatality HS-800 Gaming Headset and a Creative Sound Blaster FX Sound Card.
Creative's Fatal1ty Gamer Headset provides power, precision and comfort for the serious gamer. The ergonomic, lightweight design, with padded velvet earpieces and headband, ensures a comfortable fit during extended gaming sessions. Weapons, positional cues and environmental audio effects sound fantastic through the high-quality drivers, with excellent bass response for powerful explosions. The noise-cancelling microphone transmits voice commands clearly to other team members, and it can be detached for easy storage or to use the headset like regular headphones. In the heat of battle this is the headset that won't leave people stranded - and that's why Johnathan 'Fatal1ty' Wendel, the world's best known pro gamer, uses it.
The Sound Blaster Audigy Fx also features a 24-bit 192kHz digital-to-analog converter (playback), 106dB SNR and a high-end 600-ohm headphone amplifier for studio-grade monitoring. Interchangeable full-height and half-height metal brackets are included to give you the flexibility of installing the sound card in small form factor desktop PCs.
- Ergonomically designed and acoustically tuned for gaming.
- Padded headband and earpieces for ambient noise exclusion and comfort during long gaming sessions.
- Swivel joint earpiece design adapts to every user.
- Detachable and adjustable noise-cancelling microphone.
- In-line external volume control with microphone on/off.
- Excellent response for voice communications and dynamic in-game audio, with extended bass response for high-impact explosions.
Headset Specifications:-
- Frequency 20 Hz - 20 kHz
- Nominal Impedance 32 Resistance (Ohms)
- Nominal Noise Level 110 dB
- Noise Reduction No
- Micrphone included Yes
- Removable Yes
- Frequency 100 Hz - 15 kHz
- Nominal Impedance 10000 Resistance (Ohms)
- Noise Reduction Yes
- Port Headphone Jack 1x 3.5 mm
- Microphone Socket 1x 3.5 mm
Sound Card Specifications:-
- Signal to Noise Ratio: 106dB
- Sound Output Mode: 5.1
- Standards: SBX Pro Studio
- Sample Rate: 16-bit to 24-bit playback sampling rates: 44.1, 48, 96, 192kHz‚16-bit to 24-bit recording sampling rates: 44.1, 48, 96kHz
- Compatible OS: Windows Vista‚Windows 7‚Windows 8
- Package Type: OEM
Only £39.95 inc VAT.
ORDER NOW
