Creative Card Help
19 Jan 2005
I have a 5.1 Creative card in and I'm pretty sure installed, on my ASUS Motherboard there is also sposed to be 5.1 sound.
I have the manual to my mother board and have put the leads in what I think are the right sockets but still only 2 speakers are sounding. When I change the leads over into my soundcard there is no sound at all. Do I need to change a setting or something?
Any help would be appreciated. Thanks
How do your speakers connect to the sound card? do you have a seperate amp or decoder of sorts?
I'm not sure how au fait you are with pc's so don't want to patroniose you.
Have you been into My Computer>Control Panel>Sounds and Audio Devices..
under speaker settings go to 5.1 speaker settings.
Also you might want to look at the creative Audio HQ. You may find
this in your programs>creative (from the windows start menu). What
specific card do you have and what is your speaker set up called?
B
Done all that (pretty confident with PCs), the creative HQ isnt there anymore for some reason. The speakers go through my sub and then 3 wires (black green and orange) connected into the soundcard, cant remember the exact model number though.
