Creative Pebble 2.1 audio automatically lowers/raises?
27 Jan 2005
Expat in HK
Just bought these after liking the 2.0's but the audio seems to audibly lower and raise from time to time.
Is this faulty?
sounds like software volume limiting have you check all settings there ?
I have Soundblaster Z and the only option I can find is Smart Volume which is turned off.
Any other options I should look out for?
