*** Creative Range Update ***
7 Feb 2011
Stoke on Toast
Got some new products from Creative that have gone live today and also some Old ones which have been refreshed with Creative SBX Pro Studio instead of the former THX Pro Audio.
Creative Sound Blaster Audigy Rx (70SB155000001) @ £59.99 inc VAT
The optimal recording solution for PCIe sound card platforms Experience the wonders of multi-channel surround sound and create high-quality podcasts! Hardware-accelerated EAX effects let you incorporate many types of sound effects with ease! Sound Blaster Audigy Rx features an SNR of 106dB, a 600-ohm headphone amp for studio monitoring, and a software suite that allows full audio customization.
The Sound Blaster Audigy Rx is an advanced sound card that represents the perfect upgrade from basic motherboard audio to immersive cinematic surround sound. With its advanced chipset designed to process our legendary EAX reverb engine, you can look forward to experiencing superb 7.1 multi-channel audio. It also features an SNR of 106dB and the Sound Blaster Audigy Rx Control Panel, a dedicated PC software that allows you full control of every aspect of your sound card.
If you're big on entertainment, you would also love it for its EAX Studio software that allows for additional hardware-accelerated environmental effects to your music, movies, games as well as for your voice input and communications. Sound Blaster Audigy Rx features the Creative E-MU chipset, which was designed to process our legendary reverb engine EAX (Environmental Audio eXtensions) and deliver amazing cinematic audio playback effects without having to bog down your CPU. This ensures you get great quality effects and audio without affecting your computer's processing power. The sound card has two microphone inputs to allow you to grab a friend to sing simultaneously! Or, use the second input to record the music accompaniment while you sing. The possibilities are endless!
Enjoy reduced latency with the support of Audio Stream Input/Output (ASIO) drivers, making Sound Blaster Audigy RX the perfect solution for high-quality, low-latency audio recordings.Sound Blaster Audigy Rx Control Panel is a dedicated PC application that lets you control and customize every aspect of your sound card. You can adjust your Creative Multi Speaker Surround (CMSS or CMSS 3D) settings to upmix stereo content to your multi-channel speaker system and add acoustic depth to your multi-channel content. Or, use Mic Monitoring and Stereo Mixing to hear yourself while you record and so that you can hear the effects instantly.
The powerful EAX Studio software lets you control and perform detailed adjustments to all of the EAX Advanced HD settings such as adding environmental effects to your music, movies and games, or change the key of your music on the fly to match your voice. Enjoy premium Sound Blaster audio quality over and above basic motherboard audio with a Signal-to-Noise Ratio (SNR) of 106dB. Plus, Stereo Direct lets you listen to your music pure and unprocessed at the amazing bit rate of 24-bit 192 kHz. Keen to get started on recording right away?
Sound Blaster Audigy Rx comes with recording software such as Creative WaveStudio and Creative Smart Recorder, so you can create your content immediately! With the 600-ohm headphone amplifier, the Sound Blaster Audigy Rx is able to drive the most demanding of studio headphones.
The Sound Blaster Audigy Rx also lets you enjoy a truly cinematic experience, supporting up to 7.1 multi-channel speaker output. It gives you an immersive, cinematic audio experience for your movies, games and more!
Only £59.99 inc VAT.
ORDER NOW
Creative Sound Blaster Omni Surround 5.1 (70SB156000002) @ £62.99 inc VAT
Featuring a built-in dual microphone array for crystal-clear voice communication and customizable SBX Pro Studio audio technologies, and a studio-grade 600 ohm headphone amplifier, the Sound Blaster Omni Surround 5.1 is ideal for anyone looking to seriously upgrade their PC or Mac audio experience.
Sound Blaster Omni Surround 5.1 delivers cinematic audio immersion to your PC or Mac through a simple USB port. Powered by SBX Pro Studio technology, the external sound card instantly converts your PC or Mac into a 5.1 entertainment system with amazing positional audio and additional customizable audio effects via the included Sound Blaster Omni Control Panel software. It is also ideal for voice communication and features a built-in dual array microphone that seamlessly integrates with proprietary CrystalVoice technology to deliver amazing voice clarity for chatting or recording. And, if audiophile quality listening is your thing, Sound Blaster Omni Surround 5.1 features a 600-ohm headphone amplifier for studio-grade monitoring. Easy to install, the USB-powered external sound card only requires a single USB connection to work. That's all there is to it!
Specifications:-
- Output: 5.1 Channels
- Signal-to-Noise Ratio (SNR): 100dB
Connectivity Options (Main):-
- Headphone Out: 1 x 3.5mm jack
- Line Out : 2 x RCA jacks (Front Out) 1 x 3.5mm ( Rear L/R ) 1 x 3.5mm (C / Sub)
- Microphone In: 1 x 3.5mm jack
- Line In: 1 x 3.5mm jack
- Optical Out: 1 x TOSLINK
- Headphone Amp: Up to 600 Ohms
- Max Channel Output: 5.1 Channels
Audio Technologies: SBX Pro Studio, CrystalVoice, Scout Mode, Dolby Digital Live Encoding
Only £62.99 inc VAT.
ORDER NOW
The Full Sound card Range can be Viewed here
Creative Internal Sound cards
Creative USB External Sound cards
Creative Sound Blaster Evo (PC / MAC / PHONE / TABLET / PS4) (70GH026000001) @ £84.95 inc VAT
Meet the Sound Blaster EVO, a headset that's amazing for audio. It comes with FullSpectrum 40mm drivers, and a dual microphone array for clear communications! Beyond that, connect it to your PC or Mac via USB to unlock a full suite of audio enhancement technology! Featuring 40mm FullSpectrum drivers, the Sound Blaster EVO is the headset for amazing audio.
With its dual microphone array, you can enjoy crystal clear communications. And if you're at home, plug it into your PC and Mac via USB and boot up the free Sound Blaster EVO Control Panel software to enjoy the full suite of advanced audio enhancement technology.
Get ready to unleash the full power and clarity of your audio. Sound Blaster EVO's 40mm FullSpectrum audio drivers are capable of reproducing the full audible range of the audio spectrum, so you won't miss a beat. The headset's ear cups cover your ears entirely, passively cutting out external noise. So, when you're out and about, what you hear is only the audio that matters most to you. Dual mic array removes background noise from your VOIP calls, guarantying pristine voice clarity even in noisy environments.
Specifications:-
- Over Head Support Yes
- Speaker Driver Diameter 40 mm
- Speaker Low Frequency Response 20 Hz
- Speaker High Frequency Response 20 kHz
- Microphone Type Condenser
- Noise Cancelling Yes
- Connector Type 1 x USB 2.0
Only £84.95 inc VAT.
ORDER NOW
Creative Sound Blaster Evo Wireless Bluetooth (PC / MAC / PHONE / TABLET / PS4) (70GH027000001) @ £129.95 inc VAT
Meet the Sound Blaster EVO Wireless, a headset that's amazing for audio on the go. It comes with NFC for one-touch Bluetooth pairing and a dual microphone array for clear calls. Beyond that, connect it to your PC or Mac to unlock a full suite of audio enhancement technology! Sound Blaster EVO Wireless's FullSpectrum 40mm audio drivers are capable of reproducing the full audible range of the audio spectrum, so you won't miss a beat.
With the headset supporting aptX and AAC technologies, you're assured that the audio content transmitted over Bluetooth is crystal clear. Enjoy improved audio clarity for your voice calls through your mobile phone or VoIP service as Sound Blaster EVO Wireless supports wideband Bluetooth technology, which enables more details of the voice data to be transmitted.
The headset's ear cups cover your ears entirely, passively cutting out external noise. So, whether you're on your skateboard or on the subway, what you hear is only the audio that matters most to you. With the Sound Blaster EVO Wireless, u can even experience cinematic, virtual 7.1 surround sound when you connect the headset to your PC or Mac! Remember the occasions when you tried in vain to instruct some voice-activated application to perform a task? With high-quality dual microphone array, your commands can be transmitted accurately all the time. Use Sound Blaster EVO Wireless as a VoIP headset while connected to your PC or Mac via USB.
Specifications:-
- Wireless Type Bluetooth
Only £129.95 inc VAT.
ORDER NOW
Full range can be viewed here
Finally some new Bluetooth Speakers
Creative T3150 Wireless (2.1) (51MF0426AA001) @ £59.99 inc VAT
Enjoy your music wirelessly with the Creative T3150 Wireless 2.1 speaker system. Equipped with Bluetooth wireless technology, it works with compatible Bluetooth-enabled stereo devices such as mobile phones and laptops, providing additional connectivity on top of the usual wired connection. The satellites feature Creative's Image Focusing Plate (IFP) design that facilitates a wide acoustic sweet spot with improved sonic directivity to the listening area, giving music more focus and preserving tonal accuracy. The powerful, custom-tuned down-firing subwoofer gives your music a boost that is sure to delight your senses. The speaker system, which includes a convenient wired remote control, makes a perfect addition to any study or bedroom. The Creative Image Focusing Plate (IFP) design features an extended flare surrounding the satellite driver to provide an even wider acoustic sweet spot. This improves sonic directivity to the listening area, giving music more focus while preserving tonal accuracy. Enjoy superb bass from the custom-tuned, down-firing subwoofer with a large flared port tube that will give you just the right 'oomph' you'll love in your music.
General
Product TypeSpeaker system - for PC - 2.1-channel - wireless, wired
Dimensions (WxDxH) / Weight DetailsSatellite speaker : 7.5 cm x 9 cm x 15 cm / 230 g , Subwoofer : 18.4 cm x 19 cm x 22.5 cm / 1.9 kg
Speaker System
System Components2 speakers, subwoofer
Speaker TypeActive
Audio AmplifierIntegrated
Connectivity InterfacesBluetooth 2.1 EDR
Bluetooth ProfilesAdvanced Audio Distribution Profile (A2DP)
Transmission Range10 m
Speaker System Details
Speakers Included2 x satellite speaker - wired , 1 x subwoofer - wired
Connections
Connector TypeAudio line-in ( mini-phone stereo 3.5 mm )
ORDER NOW
Creative T4 Wireless Signature Series (2.1) (51MF0430AA000) @ £216.95 inc VAT
Creative T4 Wireless 2.1 Speaker Product Description
Riding on the technology and legacy of our popular, award-winning GigaWorks T3, the Creative T4 Wireless Signature Series continues to fulfil the promise of premium audio quality and convenience for all your entertainment needs, while giving you now the privilege of enjoying all this wirelessly too. It features sleek satellites with audiophile-grade aluminium drivers and a high-performance SLAM® subwoofer.
Indulge your senses
A major part of getting the best sensory experience out of your entertainment lies in the quality of your audio. The Creative T4 Wireless is specially engineered and designed to meet - and perhaps even go beyond - all your entertainment audio needs.
For the movie buff
Feel the excitement and action of your movies as you immerse yourself in the realistic audio playback of the movie, and without compromising on the clarity of the dialog.
Quality wireless audio
The Creative T4 Wireless is equipped with aptX® and AAC high-definition codecs, giving you high-resolution wireless Bluetooth® audio that sounds as good as audio from a wired connection.
Awesome mids and highs
The audiophile-grade aluminium driver in each satellite delivers full midrange and ultra-clear highs, giving you clear, crisp audio.
Deep, tight bass
The powerful yet compact Creative SLAM™ (Symmetrically Loaded Acoustic Module) subwoofer is professionally engineered and tuned to perfection to bring you realistic heart-thumping bass for a completely engaging gaming or movie experience.
Pair and connect in so many ways
Freedom without compromise
Bluetooth wireless connectivity gives you the freedom and convenience to move around your room with your smart device as you're not tied down by any wires.1 And with aptX, you're assured of uncompromised audio quality.
Even more connectivity options
The Creative T4 Wireless comes with an optical input for digital signals, so you can directly send audio from sources such as your HD TV or sound cards without loss of resolution. It also has RCA analog inputs for connection to your video console or DVD player, as well as a 3.5mm input for connection to smart devices and portable media players.
Switch to private listening
For late-night gaming or movie-watching, there's no need to worry about waking up the household. The Creative T4 Wireless' Audio Control Pod is integrated with a dedicated headphone jack so that you can conveniently plug in your headphones when the need arises.
You're in control
Press, tap and turn
Fortunately, these aren't dance steps but what you can do with the speakers' multi-functional Audio Control Pod!
Press the Source button to toggle instantly between the Aux-in and optical inputs. Tap your NFC-enabled device on it for easy one-touch pairing. And finally, turn the Audio Control Pod itself to make volume adjustments.
Get the bass you want
Increase or reduce the desired bass level by simply using the adjustment knob located on the subwoofer.
Infrared Remote
The IR Remote lets you take control of your speakers without you having to leave the couch! You can perform source selection (Bluetooth, Aux-in and optical), turn the speaker on or off, adjust the volume and even control music playback.
Made for big sound
Big sound, small package
The Creative T4 Wireless' satellites are designed to deliver powerful audio despite their small size. The small footprint makes it easy for you to position them wherever you want, while saving space on your desktop or living room table. The satellites can also be wall-mounted, making them ideal as TV speakers in the living room. Simply remove the detachable satellite desktop stands and they're ready to be mounted (brackets not included).
SPECIFICATIONS
- System Configuration 2.1 system
- Dimensions Satellites: 150.0 x 85.0 x 90.0 mm (5.91 x 3.35 x 3.54 inches)
- Subwoofer: 215.0 x 235.0 x 290.0 mm (8.46 x 9.25 x 11.42 inches), Infra Remote Control: 12.0 x 50.0 x 123.0 mm (0.47 x 1.97 x 4.84 inches), Power Adaptor Cable Length: approx 1.5m, RCA to 3.5mm Stereo Cable: approx 2m, Wired Audio Control Pod Cord: approx 2m, Wired Audio Control Pod: 40.0 x 70.0 x 70.0 mm (1.57 x 2.76 x 2.76 inches)
- Weight Satellites: 465g (16.4ox), Subwoofer: 5.94kg (13.1lbs), Wired Audio Control Pod: 265g (9.3oz), IR Remote Control: 37g (1.3oz)
- Bluetooth® Version Bluetooth 3.0
- Bluetooth® Profile AVRCP (Bluetooth Remote Control), A2DP (Wireless Stereo Bluetooth)
- Supported Codecs aptX, SBC, AAC
- System Requirements
- For wireless streaming:
- Compatible Bluetooth devices that support the Stereo Bluetooth Profile (A2DP)
- For one-touch pairing: NFC-enabled devices
- For media control functions on IR remote: Compatible Bluetooth devices that support the Bluetooth Remote Control Profile (AVRCP)
- For direct connection to optical input: Television displays, sound cards or other audio devices with optical output
- For direct connection to Line-in jack: Analog audio devices with a 3.5mm output or RCA output
- For headphones output: Headphones with 3.5mm stereo jack
- WARRANTY - 2-year limited hardware warranty
PACKAGE CONTENTS
- Two satellite speakers
- One subwoofer
- RCA-to-3.5mm stereo cable
- Wired Audio Control Pod
- Infrared remote control
- Power cord(s)
- Safety and Warranty leaflets
- Quick Start Guide
Only £216.95 inc VAT.
ORDER NOW
The whole Range can be viewed here
Maybe a dumb question, but is the Audigy Rx better than the Sound Blaster Z? The Z claims to have a signal to noise ratio or SNR of 116dB, whereas the Rx is shown as 106dB?
Hmmmm interested in that sound card...as mine went in the bin
could I use my Black , Orange , Green 3.5mm jacks from my Logitech Z506s in that card please TwsT?
some cool products there
the audigy RX looks like it could really be popular for those recording their own audio
assuming we are talking abotu the RX it has a sub rear front and center and 2 microphone inputs I am going to go down and inspect one now for you. but yes it will take the 3 outputs you have.
Right yes green orange black, Plus a separate Headphone out and then two mic/line in ports
i think the usb version is different to the HS800 we currently stock
as far as we are aware. there is no plan to discontinue
Just so you guys know the Evo does virtual 5.1 surround sound...it's a fantastic headset indeed with a built in microphone to the headset.
Volume control on the right cup and also when you press in the right cup it can pause/start tracks, answer your phone etc.
Terrific sound quality to boot :)
