MP3 enhancement
squiffy said:Which doesn't work. Sounds better both disabled (24 bit crystilizer and CMS3D)
james.miller said:...i was going to say something then but a just cant be bothered![]()
M0T said:Everything sounds richer with the crystalliser on, its less flat and MP3 like. I really noticed when I had to take the card out for a bit.
CMS3D is terrible though, I have never understood why they bother with stuff like that, it just makes everything sound odd.
squiffy said:You need better gear then. Crystializer produces a unusual midrange warbling on bass guitar, I guess because PC speakers have limited midrange this boost helps. But on a Hi-Fi system it just makes it sound funny. It does make it more trebly, but it has side effects too.
Buckster said:you can do better - 2nd hand Audigy 4 Pro.
has the same DACs as the X-Fi Elite
Mark.
