Just recieved this new sound card from OcUK for £18 (OEM). However, i'm having some problems.
If i go into the speaker configuration settings, i do the channel and noise test and they both show that all speakers are working and are working in the correct positions according to the layout of the room.
However, in windows itself, i am only getting sound from the two front speakers or whatever is plugged into the green plug. (I am using 3 cables in total to go into the sound card. One for the two front, one for the center and bass, and one for the two surround.)
The sound used to work perfectly using onboard sound.
Anyone come across similar problems?
