Creative SoundBlaster X-Fi Fatal1ty FPS - OEM
18 Aug 2005
Shropshire
Does anyone know if you can get this card in the OEM Format.
I don't want the stupid panel for the front lol,
If this card isn't available, is the XFi Music the same just without the rip off Fata1ty name ?
I haven't seen this card in OEM.
The x-fi fatal1ty comes with x-ram whereas the xtreme music doesn't. Not really sure if the benefits outweigh the price difference though.
I'm interested too, wondering if I should opt for the OEM music and save loads of money or ***** some cash on the fatality to get the 64mb RAM. I do a lot of gaming and game dev work. Does the 64mb really make THAT much difference? Considering I'll have the card for years (it's replacing an original SB Live) should I just go for the fatality? :confused:
There was a review that showed the XFi Fatal1ty game some FPS Back to the game, it was only three or four Frames Per Second though so i don't think its noticeable.
If the sounds quality between the XFi Music and Fatal1ty are the same, then i will get the XFi Music :)
quality is the same, boost with the fatality is nothing but a red light on the card :/
oem music can sometimes be a dell one, which has cut back features.
How can you tell if it's a dell one or not? Is OcUK likely to have the dell stock?
EDIT: Just bought the Retail one, didn't want to end up with a cut down version. Cheers for the heads up. :)
Creative Sound Blaster X-Fi Xtreme Music - Retail (SC-034-CL)
OR
Creative Sound Blaster X-Fi Xtreme Music + HS600 £29.99 Gaming Headset Bundle - Retail (SC-042-CL)
The Bundle is cheaper :confused:
Is there any difference between these two ?
Could phone/email OcUK just to check the X-Fi with that bundle is the full retail one. I know it says retail but there is a small chance it could just apply to the headset.
If it is retail then it's an easy choice since it's cheaper and you get a free headset.
The one with the Headset is the FULL Retail version, i just spoke to a chap at the shop called Chris, who confirmed this :)
Ive ordered one now, upgrading from an Audigy 4
I've got a Medusa headset, so i will report back tomorow night on how the sound is :)
I got the Extreme music with the free headset in the end, was quite impressive, not too hard to setup at first.
Then i started trying to use teamspeak.
Its a pain in the backside, it keeps making me listen to what i'm saying and i have some how managed to stop it.
It does sound a lot better in games than my Audigy 4 did :)
